Sarno Earth Drive
- sugarinthegourd
- RnFR
moved to REQUESTS FOLDER.
- sugarinthegourd
Here's a pic of the back of the board. 3 board-mounted pots, maybe an IC in the center. Looks like fairly low parts count. YATS?
- caspercody
Any updates on this?
- Kitrae
I did not photograph the other side when I reviewed it, but I can tell you is is TS based.
Kitrae - Muff junkie
Big Muff Page
http://bigmuffpage.com/
Tonbender Timeline
http://www.bigmuffpage.com/The_Tonebender_Timeline.html
Big Muff Page
Tonbender Timeline
- Cub
Thanks, Kit ! I half expected it to be TS based. Brad Sarno did well on this one.
Normally, I really don't like the sound of a Big Muff going into a Tube Screamer, but the clip you posted with your review sounds great.
I might know someone that took some gut shots of an EarthDrive they bought years ago...this same person might have done a full trace after getting pissed off that the diodes were gooped and the IC sanded. I was able to find the pictures and some of the parts values for now.
I do know the IC was eventually determined to be a 4558; the sanded one was put in a test circuit and had voltages measured at the various pins under several sets of conditions that matched pretty much exactly with a labeled 4558.
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
I redrew the circuit diagram, so you can see the circuit structure better.
My guess for the IC are TL072 or CA3240 and for the germanium diodes 1N34A.
I know a TL072 was tested and didn't measure in the same ballpark as the mystery IC; not sure about the CA3240. Also not sure about the exact testing methodology, whether it was a reliable way to make an informed guess, or anything else about that part really.
- mauman
Your DMM probably uses around 1mA for testing diodes, while the Peak used 4.29 mA. Diode forward voltage drop varies with current, and makes a curve that increases with increasing current. A reading of 241 mV @ 1 mA and 644 mV @ 4.3 mA would be in the normal range for Ge diodes.
- Manfred
- Manfred
I got a bunch of 1N60P Germanium diodes that look the same as the diode on your snapshot, also the readings are in the same range.GratefulEight wrote: ↑19 Sep 2022, 02:40 The Ge diode (clear DO-7 with 2 black stripes--see picture) that survived de-goop measured Vf = 0.644V, with a test current of 4.294mA on a Peak DCA55 tester; a standard DMM said 0.241V on diode test mode. Not sure why the discrepancy...leakage? Low DMM battery?![]()
Reading: Vf=0,736V at 5,00mA
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
So essentially Paul Cochrane's Timmy, minus the bass pot but with half ge diodes?
- Manfred
In fact the same circuit structure, then what's the point of gooping components.Nocentelli wrote: ↑19 Sep 2022, 11:52 So essentially Paul Cochrane's Timmy, minus the bass pot but with half ge diodes?
The circuit copier fears nothing more than that his circuit is copied.
