Page 1 of 3
Wampler - Black '65
Posted: 13 Feb 2012, 16:58
by HHR18
Any bought this? Sounds like a great pedal, check here:
Re: Wampler Black '65
Posted: 13 Feb 2012, 17:55
by Oliphaunt
The opening to that demo sounds really good! I would like to have heard the full gain range on the demo rather than just %50 and full.
Posted: 15 Feb 2012, 09:48
by Ice-9
I would definately be interested in trying to get this one breadboarded.
Posted: 15 Feb 2012, 10:11
by Ben N
Great sounding demo. I have no idea what's inside, but I'd bet that if you broke out the hidden TMB tonestack of a BD-2, you'd get something very much like this.
Posted: 15 Feb 2012, 13:59
by Ice-9
In the YouTube video posed above at 47 seconds there is a gut shot of the pcb, transistors resistors and caps, no sign of any opamps, can't see if there are any components on the other side of the pcb. You may find the tone stack is more like a twin 'Blackface amp' :slap: . tempted to buy one but £185 seems a bit strong. I know Brians stuff is good though.
Posted: 15 Feb 2012, 16:48
by Ben N
Well, as I said, I have no idea how Brian went about it, and I'm sure there's more than one way to skin the cat. BUT the heart of the BD-2 is a pair of discrete opamps--not ICs; and a tone stack taken right out of a Fender. Not surprisingly, the BD-2 sounds a bit like an overdriven blackface amp straight out of the box. This is something I'm sure Brian is plenty familiar with.
Posted: 15 Feb 2012, 16:56
by Ice-9
Sorry Ben I had forgot the topology of the BD2 and that it has a fenderish tone shaping section in there (control less). The BD2 tonestack is way simplified having a single tone control and it would be interesting to see if Brian has gone down the route of building a discrete op-amp stage or two.
Posted: 15 Feb 2012, 19:28
by Ben N
Never mind. Only 3 trannies in that gutshot, and they are pretty far apart for a discrete op amp.
Posted: 15 Feb 2012, 22:32
by HHR18
Gut shot taken from the video:
Posted: 16 Feb 2012, 09:19
by Ben N
Thanks for the nice cap. 2x-sided board, though, so not much we can make of it. Except baseless speculation, which is always fun, so: Double Fetzer valve + tone stack + mosfet output stage, a la ROG? Nah, no trimpots. Then again: download/file.php?id=13073&mode=view.
Posted: 16 Feb 2012, 10:30
by briggs
Ben N wrote:Thanks for the nice cap. 2x-sided board, though, so not much we can make of it. Except baseless speculation, which is always fun, so: Double Fetzer valve + tone stack + mosfet output stage, a la ROG? Nah, no trimpots. Then again: download/file.php?id=13073&mode=view.
Ohhh, I love random guessing. I'll say 4 jfet stages (I'd take a guess at MPF102 fets due to their high pinch off voltage and generally clearer tone) with a gain stage and buffer stage running into the tone stack and gain control after the first stage, then two clipping stages and a volume control, the gain boost will switch in a couple of large caps over the source resistors of the last two clipping stages.. I'm pretty sure that's wrong straight away as all the Jfet stages look like they are gain stages and not buffers but it's fun to pretend...
Posted: 17 Feb 2012, 10:28
by RnFR
It probably follows wamplers other ampish designs. matched JFETs, ROG style.
Posted: 20 Feb 2012, 03:24
by MoonWatcher
Ben N wrote:Nah, no trimpots.
But the drain and source resistors that must be in those "3 banks of 6" probably are the same or similar. I like how there are basically what look like test points for confirming 4.5VDC next to Q2, Q3, & Q4, along with a convenient place to drop in a probe to ground.
Q2/3/4 also appear to have small value caps to probably bleed off some high end, unless they are "peaking circuits."
Kind of interesting. A boatload of caps for just 3 transistors (with Q1 being my guess is an input buffer).
Posted: 20 Feb 2012, 13:12
by mrkaploca
I guess those are J201.Brian is pretty consistent in choosing parts.
Posted: 20 Feb 2012, 13:44
by briggs
It sounds quite open, bright and dynamic for J201s, but you could well be correct.
Posted: 23 Feb 2012, 04:40
by indyguitarist
it's pretty straight forward. jfet gain stages, j201 because I like how they sound most of the time. All of them sorted so we can use specific drain resistors. There's no magic, no voodoo.. just a circuit that I tweaked and tweaked on until it sounded as close to a twin as I could get it.
Posted: 23 Feb 2012, 10:11
by briggs
indyguitarist wrote:it's pretty straight forward. jfet gain stages, j201 because I like how they sound most of the time. All of them sorted so we can use specific drain resistors. There's no magic, no voodoo.. just a circuit that I tweaked and tweaked on until it sounded as close to a twin as I could get it.
Ahhh, so the J201 does return! Chhheeeeers Brian, it does sound pretty good. If you don't mind me asking how many Jfets don't make the grade sorting wise? I found that when I started sorting jfets around about 50% didn't meet my tolerance levels...
Posted: 23 Feb 2012, 10:19
by Ice-9
Thanks, Nice bit of insight to the balck 65 design.
Posted: 23 Feb 2012, 12:42
by RnFR
:horsey: woohoo! my vague guess was right! I'd still like to see what kind filtering is goin on here.
Posted: 24 Feb 2012, 05:08
by MoonWatcher
briggs wrote:I found that when I started sorting jfets around about 50% didn't meet my tolerance levels...
I seem to remember Brian Marshall going thru all of that with the Liquid Sunshine, until he finally found a source (or sorting method) for consistent ones. But in that case, they are 2N5458's, right?
I personally don't care for doinking around with j201's because of the sorting part, even though they could all probably be sub-grouped for different projects.
But a tip of the hat to those who DO take the time to sort those things. :thumbsup I wonder how it ranks compared to picking fly shit out of pepper with boxing gloves on? :hmmm:
