SIB - Echodrive schem?
- devastator
realy any one has something about this delay pedal ? inside pics ?
- jupagblkxten
I believe I have some gut shots I took before selling the pedal years ago. I'll take a look when I get home and see if I can find them.
- devastator
- devastator
- Bernardduur
Ah........ that PT2395 is known
On second thought, I only know the PT2399....... hmmm, what's the difference?
- Brian M
Bernardduur wrote:Ah........ that PT2395 is known
Datasheet: http://www.datasheetcatalog.org/datashe ... Xuuysq.pdf
There is a much better datasheet i have seen before, but this one came up first in google.
Interestingly enough the pt2395 uses adaptive delta modulation... I'm not sure what the "adaptive" part means. Delta modulation is known for being efficient with bandwidth, but not so much for it's preservation of audio quality.
small bear sells the pt2395's.
- briggs
- Dirk_Hendrik
I thought it was in the Dan Echo (as well)briggs wrote:I believe that is the chip used in the PB&J Danelectro.
It is for sure in the Visual Sound H20.
- Bernardduur
Wow; an analog tube driven echo
devastator wrote:I found an inside pic !
Do you have tube board pics?
- devastator
Nope I found that pics on thegearpage "gutpics" thread.
The delay looks really interesting, too bad that the price is so high.
