Way Huge - Ring Worm?
- gigelmargel
Hello all,
I've just discovered this amazing ring modulator from Way Huge:
Anyone has some more information about it?
I am very curious how to all a LFO to a ring modulator (I have a clone of Maestro Ring Modulator).
Best regards!
Best regards!
- gigelmargel
Maybe the LFO is digital? I am very interrested to see the schematic of the LFO, because it can be used in many other purposese
- phibes
Doubt it's a digital. There are a few ways of doing it. You can work the LFO in with a Wave Generator and hook up a rotary switch between the different waves going to the modulator. There's lots of info in synth forums. As far as the ringworm, it's hard to say without knowing what chips are inside.
Ken
Ken- gigelmargel
Thank you phibes!phibes wrote:Doubt it's a digital. There are a few ways of doing it. You can work the LFO in with a Wave Generator and hook up a rotary switch between the different waves going to the modulator. There's lots of info in synth forums. As far as the ringworm, it's hard to say without knowing what chips are inside.
I will search on the synth forums for a complex wave generator like in the Ring Worm. But how I can use it in an EHX Frequency Analyzer to modulate the signal?
- phibes
The Frequency Analyzer is a fun circuit. There's info in the 8038 datasheet for modulation. I think there are a few projects on google too. You can get 3 waves outta the 8038. You using the 1496 for a modulator?
Ken
Ken- gigelmargel
No, I use an AD633...MC1496 it's n Maestro Ring Modulator.phibes wrote:The Frequency Analyzer is a fun circuit. There's info in the 8038 datasheet for modulation. I think there are a few projects on google too. You can get 3 waves outta the 8038. You using the 1496 for a modulator?
