Hi guys im new here.
Firstly i just did blueclipper from tonepad with breadboard without on off switch.
My problem is that i cant get any effect. But it gives clean tone. I checked circuit maybe a houndres times. I couldn't find any problem. Is it beacuse switch ?
Make sure your power/ground rails are connected all the way down. Some breadboards have them disconnected in the middle of the board (in case you want to run multiple voltages in one circuit).
