not sure if it's the right section to post it, but here's my problem. My friend gave me his peavey 6505+112 because the internal fuse melted over and over. so i cheched in it, i tried new power valves, and i checked for damaged resistors that could overdrain current, but i found nothing. I also checked for short circuit, but i found nothing. Just to say the valve heaters still works, and led toon but no sound come off the amp.
here's the amp schematic : http://www.prowessamplifiers.com/schema ... 505112.pdf
the fuse is F2.
any ideas?
regards
