Attached is a zip file of ALL of the effects circuits from his site.
Rock on, and may the creative spirit of the Great Escobedo be with you always.
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
Thanks for the perspective... well, I've never owned a bow-teek pedal in my life (except the hartman analog flanger, which is just fabulous) and am pretty happy with the budget/lowfi stuff I buy. What puts me off is the attitude of the companies, more than anything else... the FB debacle comes to mind. I have no idea why people have a problem admitting that they at the very least based the design on something that already exists.Nocentelli wrote:I'v not heard of Tim Escobedo posting here or anywhere else DIY-pedal related for many years: If you did track him down and he said "No, you cannot use any of my circuits in a commercial venture even with modifications" a) How would you feel? b) How could he stop you? There is pretty much nothing any designer can do that would stop use of their circuit - If you were to sell an "Escobedo PWM pedal", and marketed as such, there might be trademark issues but that is it. Morally, it's a different ballgame. However, speaking entirely personally, but with the vague notion of consensus on this board, what is morally wrong with most booteek companies is when they market a pedal as a revolutionary breakthrough in sound sculpting, and it turns out to be YAFF/YATS/YABM/Timmy.
If you feel, or if Tim tells you it is wrong to use his design in any way, shape or form, I'm sure you could find another workalike design by someone else who has less stringent restrictions on their usuage, or even work up a workalike using different components that you can claim as your own.
Thanks a lot pinkjimiphoton. I'll drop him a line sometime this week. BTW, I love your videospinkjimiphoton wrote:tim escodbedo's email is at the bottom of the circuit snippets page, and he DOES respond to some things... i emailed him a year or so ago, and he replied. fwiw
Thanks guys. So far it's been a no-go since my PWM-based circuit refuses to perform on PCB, but does fine on breadboard. I've been tied up working on some other designs, I'll probably explore this a bit down the road and write to Tim once I get it working. Cheers!DrNomis wrote:I'd say at least discuss it with Tim Escobedo first and let him know that if you do make any money it's going to some worthy causes, you never know, he might just give you permission, the only way you're going to find out is by asking him, it's always a good policy anyway....![]()
My two cents worth....
I think the PNP transistor is cancelling out a few frequencies in the Push me Pull me to make the octave effect. I was using a Tele with a p90 in the neck and overwound 60's single in the bridge. I'm located in Japan for the time being, so I end up renting studios out and use whatever they have. Usually it's a Roland Jazz Chorus. Thanks!tabbycat wrote:hey guy, welcome to fsb. i hope you have a riot here. get in.
thanks for posting the demos. i like the jerkulator best. very punchy attack with a satisfying after-rattle. it’s a hammer of a pedal.
the sound on the pushme was very percussive and toppy, is that the pedal cutting lower frequencies or how you generally like your tone? what is your set up on that? hums or singles.
escobedo is classy. the seeds from which so much great stuff can grow. nice builds.
