I want to build a footswitch with 2 LEDs for the Reverb and Tremolo effects of my Vox ac15, as the current one I got (a no name one) doesn't have LEDS, which is not very useful when I want to know if reverb is on or off, as an example. I precise that I'm also re-housing the wiring in a smaller box to reduce the space it takes on my pedalboard.
The footswith will have one LED per effect to check if it is on or off, and normally these LEDs will be powered by the amp, as the current footswitch I got is powered this way by the ac15.
I'm trying to figure out how to wire all this in my litte box. I'm a begginer in DIY electronic, and that footswitch is the pretext to start well
So far I got this wiring diagram (inspired by another one I found):
Can someone tell me if it is right or wrong ?
Also, in the event that the amp wouldn't power the LEDs, can you tell me how to wire a 9V battery to the rest?
