Did I burn out my LED?
Posted: 26 Mar 2012, 23:46
by digitalzombie
Newbie question. I'm wiring up an UV colored LED to a pedal that didn't come with one. As far as I can tell my wiring is fine. I have a 3.3k in line between the cathode of the LED and voltage. Put the battery in, clicked the stomp, and the LED lit. Clicked it off after a second, then back on, and after about a second the LED changed to a kind of bright purple and won't come back on. Do I need to bother to check my wiring to see if something just came loose, or is this LED toast and it's back to the drawing board? I used electrical tape to shield my connections after soldering, so I don't see how it could be shorting out any where. I'll post pictures if someone thinks that'll help, but does that sound like the behavior of an LED that just burnt itself out?
Re: Did I burn out my LED?
Posted: 26 Mar 2012, 23:50
by digitalzombie
Ugh!!! Nevermind! Just took another look and I ordered 3.3ohm.... Not 3.3k.... fml...
