2 in 1 stompbox HELP!
Locked
juan_felt
Post by juan_felt »
Hi, I made an overdrive and a booster. I want to put them in one case, sharing the input, output, dc jack and battery clip. How do I have to wire them to make in work?
I tried to do it but i get a hum. Both effects turn on and seem to work under that annoying noise.
Help Please!
Thank you...
Westbury
Been thanked: 7 times
Post by Westbury »
Switch 1's lug that normally goes to your output jack, should go to switch 2's lug that normally goes to your input jack.
Then run the output lug from switch 2, to the output jack.
Duckman
Has thanked: 320 times
Post by Duckman »
juan_felt
Post by juan_felt »
Thank you all! I did everything again, following the GGG scheme. Works perfectly now!
Duckman
Post by Duckman »
:thumbsup
Locked
