TS808 works with battery not with AC adapter
I have a TS808 re-issue that will work with a battery but nothing when using an AC adapter.
What should I check first? The diode in the power section? If someone can give me some tips to try I'd appreciate it.
- alteredsounds
I'd stick your meter across 1st the adapter and make sure its 9v and correct polarity and working, 2nd have a look at the socket in the pedal, see if you can get a 9v reading across where it goes to the board, maybe the socket is broke? If it works from a battery there is no reason why a correct polarity 9v dc adapter wont work.
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
check the adaptor - AND - does it have the right size dc socket plug on it ???
If it has a larger hole in the centre of the plug it will not make contact with the pin - should be 2.1mmm plug!!!
If the battery works then the pedal socket is okay
- bajaman
If it is an AC adaptor - it will not work. You need a DC adaptor with a negative centre 2.1mm female socket plug on the end ( preferably 9v DC regulated too)but nothing when using an AC adapter.
I went over the solder points under the power jack and it works. Must have been a bad solder point from the factory.
Thanks for the replies anyway.
Should have checker that first.
