Is it just a case of adding another 100k resistor next to the 50k and moving the output and bridge across one?
If you could use this drawing, much appreciated!!!
Yeah this does help, thank you!bato001 wrote:Put the 1st 100K resistor right where the 50k resistor is supposed to be. THen solder the legs of the 2cnd 100k resistor to the legs of first resistor. Piggy backing them works just fine and is not that difficult to do. No need for a pic to explain this one I think.
Either that or use a 47K resistor or a 52K resistor, which are easy to get : ) Or add another column and put it right next to the other one.
