Ge Transistors
gurishka
Has thanked: 23 times
Post by gurishka »
Hey all,
I just recently got in a batch of some PNP Ge transistors (GT308B) from Moscow with the Hfe ranging from 39-59....
Any ideas on what I can use them for? I was hoping that their Hfe would be up around 80 or so to use them in some Fuzz Tonebenders and the like....are they any good still?
All suggestions welcome.
PokeyPete
Been thanked: 43 times
Post by PokeyPete »
Sure they are! The higher gain ones would make rangemasters. Or, Q1 in a fuzzface.
Traditionally tonebenders use 70 to 100 gain transistors, but if I remember correctly
Fulltone's Soulbender reversed the order of gains and used transistors with gains of
78 to 89 as Q1, 67 to 77 for Q2, and 45 to 66 for Q1. (The gain ranges may not be
exact but they are very close.) You can take the lower gain transistors and put them
in darlington pairs to increase their gains by a good bit. At the very least you can
use each one as a diode by only using the base and emitter. I'm sure others will
chime in with more options. :D
–Hunter S. Thompson
gurishka
Post by gurishka »
Would making them a darlington pair be a bad thing? :(
Hfe1 x Hfe2 etc...
Wouldn't it be too high? Or again it wouldn't matter having the hfe 1000 :scratch:
bato001
Has thanked: 31 times
Been thanked: 38 times
Post by bato001 »
Build a Big Muff with a .1uF electrolytic between Q2 and Q3 (instead of a ceramic .1 uF cap) and use your low gain germaniums for the Q2 and Q3 transistors and 2n5088's or similar high hfe transistors for Q1 and Q4.
PokeyPete
Post by PokeyPete »
gurishka wrote:Would making them a darlington pair be a bad thing? :(
Hfe1 x Hfe2 etc...
gurishka, I'm just throwing ideas at you. In the '50s and '60s when these things were just becoming popular,
they were used for all sorts of purposes. Not just amplification. They were used as switches.....they turned on
light bulbs...they activated relays. They revolutionized computer design. If you limit them to the few stompbox
circuits that famously used them, then maybe your collection will be mostly wasted. But if you treat them as just
another transistor, there are lots of things you can do with them.
–Hunter S. Thompson
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
viewtopic.php?f=13&t=16858 - Perfect gain ranges for the Rangemaster mkII
I am Klon.
gurishka
Post by gurishka »
Hey PokeyPete and briggs, thanks very much for the ideas...I love the La Revolution Deux site briggs....I try and pop over and check it out when I have some free time.... any and all help is appreciated very much. :)
So you think a Rangemaster Mk II is the way to go? I was thinking some of those Bronto Boosts and Skyripper Fuzz pedals by NVN/Joe Gagan would be good but they're obviously a bit down on Hfe... :(
Would they still work in a Tonebender?
gurishka
Post by gurishka »
Hey briggs have you read this article?
http://www.smallbearelec.com/HowTos/GeD ... nPairs.htm
I'm finding it interesting and for a noob like me, quite scary to think about trying to implement... :S
jrod
Has thanked: 413 times
Been thanked: 46 times
Post by jrod »
^^^HAHA I was just going to post that article for you check out!
bato001 wrote:Build a Big Muff with a .1uF electrolytic between Q2 and Q3 (instead of a ceramic .1 uF cap) and use your low gain germaniums for the Q2 and Q3 transistors and 2n5088's or similar high hfe transistors for Q1 and Q4.
bato001, why an electro instead of ceramic or film? :scratch:
Godebut
Post by Godebut »
Germicide circuit says its good for low,leaky ge's? Not verified true by me personally
