Frantone - Vibutron  [traced]
KindaFuzzy
Has thanked: 74 times
Been thanked: 257 times
Post by KindaFuzzy »
Finally found one of these, and there's a lot less inside than I thought. Full gut shot gallery here: http://www.flickr.com/photos/35422385@N ... 803855603/
Chips are ICL8038ccpd, ua741cp, tlc2262cp, and a 2n7000 mosfet. Tracing will be done soon.
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Cool!
Does the speed knob works the other way around as the one I had in a while ago (too short to make a schematic of even take pics)
Datasheet of the ICL8038; precision wave form generator, cool!
KindaFuzzy
Yeah, it's backwards and has a huge range of speeds from super slow to crazy fast. The sine/triangle/square switch makes a big difference too, but gets lower in intensity as you go from square to sine, which is a little disappointing.
KindaFuzzy
OK, here's what I've got, not verified yet since I don't have my 8038 chip yet, but should be good.
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Simple design but very cool! I've read about the sine feed of the 8038 being weak before.
Image Ken
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Sweet! Sounds kinda like the function generator chip that C'bread used on that tremolo thing that I can't pronounce.
By the way, has anybody done the relay switching on any of the Frantone boxes? I don't recall seeing it fully traced, but surely must have. I think I will search for that now. :thumbsup
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
phibes wrote:Simple design but very cool! I've read about the sine feed of the 8038 being weak before.
I'd buffer the output from the "Blend" pot - it would guarantee that anything you load it with wouldn't affect the operation of the FET.
The 8038 is quite expensive and draws a lot of current. You can get the same result with a quad op-amp and a couple of Schottky diodes - I use the conventional comparator and Miller Integrator triangular-wave oscillator (used in most phasers and flangers for the LFO), and then an op-amp and diode-based shaper for a reasonable sine-wave output, and you can get the square output from the output of the comparator.
The "spare" op-amp in the quad package can be used to drive the FET.
I'll try out an experimental version shortly - it's going to use two TL074s and a V-FET . The FET will be a BS170 as I don't stock the 2N7000, but the results should be similar, but with lower current consumption. I like the "blend" approach for depth!
KindaFuzzy
The sine option is the most disappointing as far as depth goes for sure.
KindaFuzzy
So I ordered some 8038s from ebay, and they didn't work, so I ordered some more from another guy and it looks like they don't work either. I measured the voltages on the one in the pedal, and it's pretty obvious even without using my scope, that on the three function output pins the voltage is jumping up and down like it should, but nothing when I breadboard the chips I got. I tried the 'test circuit' from the datasheet too, and no dice.
Anyone got any ideas to test these differently, or have a few working chips they want to send me to finish verifying the schematic?
KindaFuzzy
Got the audio part of the circuit verified, I fed it a square wave from a 555 and it worked fine. Just need to get some working 8038s and we're set.
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
I just got some of these too from JunFang-Electrons on eBay. Do you want me to send a couple?
KindaFuzzy
You could, and I can send some parts in trade. Or you could just breadboard this sucker and confirm the schematic so I can dump this thing and get another pedal to reverse.
IvIark
Post by IvIark »
If I get chance to breadboard it over the bank holiday weekend I will do, but I'm not sure how much chance I'll get with the kids also off :roll: If I don't get the opportunity I'll just send them out when the post office is open, you don't need to send anything in trade.
IvIark
Post by IvIark »
That sounded really bad, I do love my kids really! :mrgreen:
Duckman
Has thanked: 320 times
Post by Duckman »
ICL8038CCPD - Small Bear @ $9.95.-
KindaFuzzy
Duckman wrote:ICL8038CCPD - Small Bear @ $9.95.-
Wow, how did I miss that?
Thanks Mark, and I feel your pain when the kid has to stay home all day too, makes you appreciate grandma's babysitting even more.
KindaFuzzy
Few months later and I finally got an 8038 from small bear, plugged it in and nothing's working, uhh. Then I started fooling around with some wires, and bang the thing starts working. As long as I connected the 9v+ to pin 8 only and not pin 6 like you're supposed to, it works perfectly. Everything dies if I connect pin 6 to 9v, or remove the pin 8 to 9v, and things speed up if you connect 7 to 8 like on the data sheet. No idea why, maybe the current drain from the crappy battery I was using went below the working voltage of the chip once it was hooked up right, but I used the same battery in the working pedal and everything was OK. The 4 other chips I got from ebay all behaved the same.
So I guess this thing is verified, sort of. If anyone wants some cheap 8038s for their own project let me know, I don't even think I'm going to build one for myself, I like my ten cent trem better.
mrkaploca
Has thanked: 15 times
Been thanked: 12 times
Post by mrkaploca »
$380 :shock: For the clipping circuit (2N7000 substrate diode)? :lol:
Razvan S.
Post by Razvan S. »
Hi guys...I'm having a hard time with this, I built it twice, it does not work...I built it from scratch the second time...EXACTLY the same sympthoms as the first
I can hear the LFO ticking, the IC does something as far as ticking goes, the switches do something to the ticking, pots as well
The only problem is that the signal is dry and does not tremolo...but the guitar passes through
Some thoughts please? Thanks! :(
greenskull
Has thanked: 33 times
Been thanked: 8 times
Post by greenskull »
Razvan S. wrote:Hi guys...I'm having a hard time with this, I built it twice, it does not work...I built it from scratch the second time...EXACTLY the same sympthoms as the first
Did you lift pin six of the function generator?
I recently built this from the Effects Layouts blog and needed to remove pin 6 of function generator from power to work (as noted in a previous post).
Also getting distortion on sine and triangle settings.... anybody else have this problem with this particular layout?
http://effectslayouts.blogspot.com/2017 ... utron.html
