D*A*M - Germanium Pre-Amplifier B-13 BOOST
beedotman
Has thanked: 402 times
Been thanked: 393 times
Post by beedotman »
Yo!
Here's one of the latest D*A*M custom one off - B-13 BOOST.
It was drawn based only on one gut shot, so there's few unconfirmed component values, but I think it could be prettey much OK and should work fine.
It's slightly modified D*A*M red rooster with added switchable output capacitor (F.A.C rotary switch).
It's sports rare White Jacket Mullard OC81D - PNP germanium transistor, so it has positive ground.
Standard for rangemaster bias string 470K/68K was changed and it could be 470K/56K (56K for sure, as seen on gut shot).
Bias resistor on emitter could be 3k9 or something close to it for correct transistor bias.
Values of caps on F.A.C switch are also not confirmed, but more or less should be ok.
:blackeye
Enjoy!
b.man
Something wrong here, circuit board have no V+ connected
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Boost and Filter labels are swapped too. I was wondering why it wasn't making sense in my head schemo wise.
I like your guys drawings a lot but you should start adding a schematic with em when ya draw it out. Would make it easier to spot stuff.
Image Ken
I was thinking to do that, you know, A4 printable friendly sized, with schemo, but I'm waiting for final DIYLC v3, not all schemo symbols are in it
phibes
Post by phibes »
Check out good ol Express Schematic. It's free, everything's in there and you can modify everything to your liking. :thumbsup
Good plan on the printer friendly part. I print to pdf from express schematic at standard size so it makes for a smooth vector print across all different printers.
Image Ken
beedotman
Post by beedotman »
sinner wrote:Something wrong here, circuit board have no V+ connected
phibes wrote:Boost and Filter labels are swapped too. I was wondering why it wasn't making sense in my head schemo wise.
Thanks for correction guys! :hug:
Hope now it's OK.
b-13.pdf
(43.25 KiB) Downloaded 64 times
beedotman
Post by beedotman »
Schematics is very good idea, will drawn it later today and post here.
beedotman
Post by beedotman »
Here's schematic.
I think I dont like ExpressSCH...
Bill_Mountain
Has thanked: 44 times
Post by Bill_Mountain »
So elegant in its simplicity.
Dr Tony Balls
Been thanked: 170 times
Post by Dr Tony Balls »
But why do a cap blend at the input and a FAC control at the out? Both do the same thing....you might as well have FAC/FAC or Filter/Filter. I have been putting FAC style control at the front of my rangemasters but leaving the output cap stock.
beedotman
Post by beedotman »
Dr Tony Balls wrote:But why do a cap blend at the input and a FAC control at the out? Both do the same thing....you might as well have FAC/FAC or Filter/Filter. I have been putting FAC style control at the front of my rangemasters but leaving the output cap stock.
:scratch: Who knows... Pedal owner wrote on D*A*M forum that F.A.C switch changes are very subtle... Personally I don't like input cap blend via pot. Switchable capacitors on input works better IMO.
Bill_Mountain
I thought I posted this earlier but I must not have hit submit or something. Anyways…
I quite like the use of two different filter topologies in this design. Also, I can totally see a need for controlling bass in and out of the circuit.
I’m not a D.A.M. fan boy (or even a guitarist) but something about this design strikes me as fun and inviting.
