It is a 2 X 6V6GT with ECC82 PI on a chassis about 8" (200mm) square, 2" (50mm) deep and has suffered slight corrosion from being stored in a damp shed for about 8 years. It still works after not being switched on for about 30 years.
There is lots of room to add more valves for a preamp and controls if required but it's square shape make it a bit awkward to build into any excising cab design I have seen.
My initial thoughts were to build something like a Fender 57 Deluxe cabinet and put this chassis in the bottom and build a 5E3 chassis populated with just the preamp components in the top.
The other option is to build the 5E3 chassis and strip the chassis for parts. I'm not too keen on this I am sure he would like to see his handiwork put to good use.
I picked on the Fender 57 Deluxe as it seems to be well documented and uses that valve configuration, but am open to suggestions and it doesn't have to be a clone of any amp, it could be a mix of say a Marshall style cab with a Fender amp.
What do you guys think, I am open to suggestions for case style and chassis arrangement but would prefer a single 12" speaker to keep the size and weight down (and I have more old 12s than is usually considered healthy).
Thanks in advance for any suggestions.
