VDL L'Overdrive  [traced]
jimpajohn
Post by jimpajohn »
Has anyone ever reversed any VDL pedals? Specifically the L'Overdrive?
I have never heard an Overdrive this smooth or a drive quite like it. My friend just bought one the other day... it came with black goop :(
jimpajohn
Post by jimpajohn »
I traced the L'Overdrive the other day. http://www.vdlanalogics.com/l'overdrive/l'overdrive.htm
DRUMROLL - It's a Marshall Bluesbreaker clone. (original one) He up'd the tie-down resistor and changed a cap or two. The bass boost switch adds a capacitor to the feedback loop of the first stage opamp. I believe that he altered some diodes to a germanium type. (They're goop'd.)
Overall I would say it's a great build. The PCB is hand made and soldered with silver solder. If anyone is interested I'll post my notes and some gut shots.
Here's a video -
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
jimpajohn wrote:. If anyone is interested I'll post my notes and some gut shots.
Always!
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
yes sure,thank you!
jimpajohn
Post by jimpajohn »
These are my horrible notes. The dots in the center are representative of the dual OP-Amp. I wrote down what values I could find that weren't covered in goop, and made educated guess on what were resistors and capacitors. If anyone can gather additional insight from the photos, be my guest. :hmmm:
jimpajohn
Post by jimpajohn »
... also looks like he "utilized" RG's layout Image :thumbsup
Frabbio
Been thanked: 95 times
Post by Frabbio »
Really interesting! Looks like the goop it's peelable, is it possible to read some of the values?
Have you discovered the differences between this and a bluesbreaker?
Thank you for your effort!
jimpajohn
Post by jimpajohn »
Frabbio wrote:Really interesting! Looks like the goop it's peelable, is it possible to read some of the values?
I haven't attempted to peel the goop. I compared the VDL to a stock bluesbreaker though. It doesn't sound like he changed much tonality wise. The VDL def has a warmer sound. I'm thinking that he swapped the stock op-amp.
jimpajohn
Post by jimpajohn »
More updates: The diodes are stock 1N914. (not germanium as previously thought)
The extra capacitor for the "bass boost" is a 10nF box cap added in the feedback loop of the first stage of the op amp.
I recently bread boarded a bluesbreaker and A/B'd it with the VDL. At the time they didn't sound the same. I realized that I had the gain pot wired up incorrectly. After I corrected it; I discovered something... no shock :roll: They sound EXACTLY the same. No difference what so ever. :lol:
Verdict - CLONE :!:
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
layouts don't look the same.
jimpajohn
Post by jimpajohn »
They're aren't the same. Rather, obviously modified to remove the support for the original switching and add support for the bass boost.
Great thread, somebody got promoted to degoop doctor ;-)
Wiseblood
Has thanked: 77 times
Post by Wiseblood »
Funny that in the video he says this pedal is the result of a 100% original project. Guess he meant original to Marshall
