Blackstone Appliances - MOSFET OD (2SV3.12) [ goop-alarm ] [traced]
hey guys,
i was surfing trought the hole post and one question left me quizzical....
--> what are the differences between junior and senior?
--> can i use the junior layout for a 3 switch version (red/brown channel, bypass and boost switchable)
thanks guys
thanks guys
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 69 times
- Been thanked: 65 times
- Contact:
The hole post ? like this ?theleftfoot wrote:i was surfing trought the hole post and one question left me quizzical....
Aaaah, the Whole post !
- telecaster
I'm feeling quizzical about where theleftfoot is from?
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
hey guys, my build get a oscillation aswell! did someone can help me to resolve this problem?abfackeln wrote: Great sounding pedal... fired up on the...... third try.Lots of usable sounds in here. Getting oscillation like other reports with the gain+ (VR7 trimmer) all the way up, but backing it down just a bit takes care of it.
raffa
- p_wats
Hey guys, I'm dying to build one of these, but want to make sure I've got the right layout: the vero layout posted earlier is a single channel only, right? Is there a layout for the whole shebang? Or a PCB to be bought? Thanks!
- roseblood11
Madbeanpedals.com had a great pcb for the two channel version ("mysterioso sr"), but the project file is not online at the moment. Maybe you should ask him?
I used his layout for my pedal and I think I etched at least two pcb´s, so I could sell you one. But shipment from germany would be quite expensive...
- p_wats
I soldered together the Jr. version from the vero layout a while back and, while it's too late to crank outside my headphone amp, this thing is pretty great sounding.
I'm thinking of using it as a preamp for a Tiny Giant solid state amp, but might just have to build the Sr. version for fun too (Madbean, any word on that batch?).
madbean
Just need to finish soldering/wiring up the board redesign. It's been a long time coming.p_wats wrote:I soldered together the Jr. version from the vero layout a while back and, while it's too late to crank outside my headphone amp, this thing is pretty great sounding.
- roseblood11
for some people it could be useful to add a second version of the wiring: two separate LED´s, the bi-color LED for the channel switch stays always on and the bypass gets a separate LED. This way it´s possible to pre-select a channel in bypass mode.
madbean
roseblood11 wrote:for some people it could be useful to add a second version of the wiring: two separate LED´s, the bi-color LED for the channel switch stays always on and the bypass gets a separate LED. This way it´s possible to pre-select a channel in bypass mode.
That's a good idea. Thanks!
- Ripdivot
That is how I did mine. I should have posted my vero layout along time ago but here it is. I used board mounted pots to simplify the off board wiring.roseblood11 wrote:for some people it could be useful to add a second version of the wiring: two separate LED´s, the bi-color LED for the channel switch stays always on and the bypass gets a separate LED. This way it´s possible to pre-select a channel in bypass mode.
Blackstone LED Mods.pdf- (36.38 KiB) Downloaded 236 times
- Ripdivot
