EHX Small Clone - Volume Mod
A musician has asked me to increase the output level of the chorus a little bit.
To do this, search for resistance R19 (10 k) and shrunk it down to desire (smaller = more output level)
I decided to solder a trimm pot (25K) on the back side of the pcb parallel to the existing R19, now you can set the output for your choice.
A relatively simple modification - have fun.
For more details visit my my blog
https://pimpyourpedal.wordpress.com/cat ... mods-misc/
- bumblebee
R19 is the one, (10k) it connects to pin 6 of the 4558.
https://pimpyourpedal.wordpress.com/201 ... olume-mod/
From the site linked above:
If you can’t buy it, build it. If you can buy it, clone it.
Could i replace the r10k by a 20K trimpot and an external potentiometer for volume control?
The Jeds Peds PCB Small Clone brings to an external volume control, with a different approach. My question is that there are many other components with different values. Would the only change to volume control be replacing the 33K resistor with a potentiometer or do any other changes need to be made?
https://2bc5345a-db4a-4df7-91d4-0b401b8 ... 0c5355.pdf
