HEXE Tadek - TDA7052A based guitar/bass compressor
pz
Been thanked: 48 times
Post by pz »
Check the DC voltages at the indicated points:
sparki
Post by sparki »
pz wrote:Check the DC voltages at the indicated points:
new bat: 9,65V
T1 - 9,65
T2 - 4,84
T3 - 4,84
T4 - 1,11
T5 - 1,06
T6 - 1,06
pz
Post by pz »
The in and out stages are ok. The problem is at T6 and T4. These points are directly connected:
And you have a 100mV difference there. Check if there is a connection between T4 and T6. A highres picture of the bottom side would definitely help.
A correct value at T4 = T5 = T6 without any incoming signal should be at about 1V. The 100mV more is quite a lot for the sensitive gain control input on the TDA chip. This is most likely the source of your distortion.
Does the gain reduction led flash when you hit the string?
sparki
Post by sparki »
I checked again, same voltage is on T4, T5 and T6. (my crappy battery droped the voltage from when i checked the one and other ic)
here's my board bottom.
had to make 2 pics couse of the pots.
and yes, the led light up as i hit the strings.
sparki
Post by sparki »
here's the whole thing in action.
https://img62.imageshack.us/img62/6974/zvf.mp4
pz
Post by pz »
What are the DC voltages at the outputs of the TDA chip? (Pin 5 & 8) Should be at about half of the supply.
sparki
Post by sparki »
Bat: 9,5V
tda: pin 8=8,8V and pin 5=0,7V
pz
Post by pz »
Ok, last step, check the voltage at the + input (pin 2) of the TDA chip. The 1uF pad, which goes into the +in look suspicious on the 1st pic (possible short to the nearest +9V track, probably it's only the perspective). If you have something like Vsupply or 0V, look for possible shorts. If the PCB and soldering are fine, the chip is fried, replace it.
sparki
Post by sparki »
ok, pin2 on tda is 1.1V, the 1uF witch leads from the poty is 4,7V and after the 1uF is 1.1V witch goes to pin2.
it's the angle of the picture, the contact is clean. (no shorts)
funny i replaced the chip today already xD i'l see if i can get another one.
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
mictester wrote:I breadboarded this, and it's excellent. There are a few mods you can easily do (like "jangle" mode, and a decay time control)
Explanation please!
roseblood11
- mictester, you never answered...
- does somebody have a pcb for this project for me?
(I'm too lazy to draw a vero layout...)
smurfberry
Has thanked: 20 times
Been thanked: 5 times
Post by smurfberry »
If someone wants to swap a (as in one) tda7052a for something real trivial like a few transistors or an op amp let me know through pm
roseblood11
they are easily available on eBay...
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
I just finished building one of these today and I think that it's a very nice sounding comp (I play bass BTW).
thanks for posting the pdf files pz!
pz
Post by pz »
Great build johnk!
I have updated the PCB design a few days ago and got the pcbs fabbed:
There is a small change in drill layout (ON/OFF led). All the new design files are here:
https://github.com/hexeguitar/Tadek-Compressor
Neur0
Completed builds: 1969 Muff Fuzz clone, MXR Phase 90 w/ R28 mod and Depth clone, X-fuzz by deadastronaut, NE555 Voltage Doubler.
Post by Neur0 »
Thank you pz!
Looks really great and is def a must build for me, using Freppo's Vero.
mictester: I would be interested to know how one would go about making the mods you mentioned.
