Joyo - JF-11 6-Band EQ [gut shots]  [schematic]
darthoverdrive
Has thanked: 121 times
Been thanked: 87 times
Post by darthoverdrive »
After a recent post about a JOYO pedal with a Freekish Blues label in it I decided to take apart my pedal to see what was inside. It turned out to be a J Wong original. While it was open I dismantled it and took a few pictures. I didn't spend much time tracing things out but it appeared to be a typical EQ pedal, input and output buffers and six gyrator circuits built around opamps. Oh and with True Bypass.
Not much to say about it. The sliders light up when the effect is engaged. It isn't dead quiet but not overly noisy either. If anything else comes to mind I'll add it in.
Has thanked: 4410 times
Been thanked: 2139 times
CheapPedalCollector
Has thanked: 452 times
Been thanked: 147 times
Post by CheapPedalCollector »
Pots in the joyo/caline/etc ones are linear btw instead of W taper... so they act a bit weird.
