How to REALLY start designing PCBs?
meffcio
Been thanked: 14 times
Post by meffcio »
Hey, fellas!
I've searched through the Internet and read many, many advices on designing PCBs, but to be honest - I've never really found what I need. There were tutorials showing some things about ground placement etc, but when I draw a schematic and export it to board designing program I just don't know what and how to do next. The ratsnest seems like one big random something and doesn't really help placing components. I can, let's say, place some pots and jack inputs regarding the whole design of the effect, but that doesn't help much, as there's a whole bunch of other components that need to have place. And as I said, ratsnest always looks to complicated, no matter how much I try to place everything correctly. I know there are some rules about placing voltage and ground paths, separating low current circuits from high current ones, etc., but since guitar fx are rather simple circuits are those really necessary? Do you guys have any advices for a PCB noob? What did already help YOU learn designing PCBs?
Has thanked: 218 times
Been thanked: 857 times
That is a question!
And the quick answer is practice, practice, practice.
A few quickies from my book.
- high impedance connections as short as possible (avoid a world of oscillation and noise pain)
- Long connections first. When having all routed and having all board space occupied except for one connection that goes from one board end to another one is an incredible pain in the butt. Having to replace a few short connections in far easier.
- roughly follow the schematic (hint; Schems read from left to right, pedals go from right (input) to left (output). Do a horizontal swap on the schem so it reads from right to left too)
- route short power supply connections straight away. Connect all these in the end. For supply lines one jumper wire usually reaches more solutions than having routed the full supply power in one trace and then having to add multiple jumpers to get signal lines connected.
- Take an existing design and the schem and copy that to see how the designer of that board worked his way through exactly your question.
and
madbean
Post by madbean »
I started by emulating some of the methods used in the Tonepad layouts. Like Dirk says, just do a lot of them. You'll find the tricks after a while. Keep your component placement logical and group areas into patterns, too. Sometimes it's good to start right at the input, sometimes it's easier to route power and then other times it's good to work several areas simultaneously and then connect them together. Always keep in mind where you want your I/O wires to go, what dimensions the board is restricted to and how organized the final design looks. Aesthetics (IMO) actually play a part. A good looking layout is well organized with the connections being direct and easily traced with the eye.
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
I tend to use vero/stripboard for the majority of my pedal builds, mostly because I don't have any etchant, toner-transfer film, or toner powder for my laser printer, when I'm designing my vero layouts I use the schematic as a guide and I try to make the layout follow it, then I'll usually go through a few design tweaking iterations till I come up with something I'm happy with, like Dirk said....practice...practice..practice..... :thumbsup
phatt
Been thanked: 338 times
Post by phatt »
Hello meffcio,
Your REAL Problem maybe that you are trying to skip the most important aspect! It's called a breadboard or similar and you proto the circuit and iron out all the bugs BEFORE you even dream about a PCB. By design that will get your brain tuned into what parts need to go where and why.
*The old saying of more haste less speed applies here.*
I know the net is a nice place to find a circuit you want and a quick dip in the tank produces a nice little circuit. Then Cross your fingers and hope it works as well as claimed,, often they don't :(
You will never learn much that way so bite the bullet and proto a circuit you think looks close to what you want and then tweak it around.
There is nothing worse that making a PCB only to find you have to bodgey it all up with flying leads to fix design issues.
These type of circuit will just slow your progress.
With a Breadboard on my bench I can print a schmo of something that looks promising, then in one afternoon I get to hear exactly what it does with my own ears through my own amplifiers. I write a quick observation on the schematic and bottom draw for future reference if needed. Very few circuits make onto Cad let alone PCB.
also learn to use simulation software as it's a handy cross-reference. Between the sim and a breadboard there is not much that I can't work out in a relatively short time. ( A scope would be nice but for the stuff I need to build I really don't need one)
To give some idea of how long it takes to develop a deeper understanding,, When I started out I spent close on 10 Years just trying to perfect a spring reverb circuit.
Some might say I obviously did not know what I was doing,, which is of course would be correct :lol: ,,, but I now have a killer spring reverb that would eat most others with brandname fronts.
The bonus was that I learned one hell of a lot about analog circuitry in that time which I would never have gained by downloading circuits and hoping it works.
A side note,, few of the reverb circuits found on the net work well enough to want to build one. heck I should know as I've built or proto'd most of them, Winky.
Phil.
bato001
Has thanked: 31 times
Been thanked: 38 times
Post by bato001 »
Like every other poster to this thread replied, layouts take practice whether they are Vero or PCB. I recommend you try laying out a few small circuits on Vero then try to translate the Vero to PCB to get a better feel for component and trace placement.
John Ricky
Post by John Ricky »
I spent four years as a design engineer for a big mobile phone company. While I've only ever driven the CAD tool once or twice, I spent a very big chunk of time sitting by the layout techs and talking them through where the tracks and components will go. And the first pass at the PCB always took a very long time, simply because it would invlove repeated placement and removal of components. After four years I was fairly good at this, althoguh it was sucha long time ago I suspect I've forgotten most of it...:D
The aim was always the same - anything sensitive was shielded, parasitic capacitance was minimised (i.e. how close are your ground planes to signal tracks, and this does still matter at audio, as you'll loose treble) and power supplies used reasonably thick tracks, but definately not power planes. Components would get dragged onto the board, and routed in. If it didn't look good, it would come back out again. It took a very long time...
John
Post by DrNomis »
A good thing is to start designing layouts for very simple circuits and gradually work your way up to designing layouts for more complex circuits, also, keep outputs as far away from inputs as physically possible, having a high-impedance input right next to a low-impedance output is just asking for trouble with self-oscillation in high-gain circuits, and, make sure your power-supply rail is properly/adequately bypassed, try to arrange the circuit grounds in a Star-Grounding system (very important for reducing hum-levels in guitar amps), make sure you have polarized components correctly oriented, if you really want a professional looking layout orient resistors, caps, etc so that the values can be read easily without having to contort yourself into knots, have a look at how components are oriented on a PCB from say a piece of High-End audio, or Military Spec. equipment for an example..... :thumbsup
And also, take your time to make sure everything's right.... :thumbsup
Give yourself regular breaks at say 15 minute intervals while you're working on a layout design.... :thumbsup
DrNomis wrote:, or Military Spec. equipment for an example..... :thumbsup
Since I don't do PCB design for that kind of appliances (and therefore never searched for these requirements, if exixtent) , could you point me out where to find mil specs for PCB design.
And,
How mucht would you learn from a military device PCB design if you don't have the requirements that were set for that appliance?
meffcio
Post by meffcio »
Damn you guys! Always there to help a noob.. :D
Seriously, thanks for all the advices. Most of them are kinda logical, but still I weren't capable of discovering them by myself. :oops: I think that now I'll just start with some silly Bazz Fuss design, and when it's perfect, choose something more advanced, and so on.
madbean
Post by madbean »
meffcio wrote:Damn you guys! Always there to help a noob.. :D
That's a good idea. Do a few designs then etch and build them. Once you get the bug, you'll never want to stop. It's great fun to make your own layouts and have them actually work :)
What I should do is press print screen a few times next time and post the shots including comments. Could help some getting insight in the process. (and especially the crap getting the last connections done), or better, getting insight in how I deal with the process. How a circuit is, correctly, layouted is highly dependent on the guy doing the layout. Madbean as an example makes layouts in a way I'd never do or even think about. But the end result always looks terrible good and when physically building the design it shows all important factors (pad sizes, component shape size etc.) were taken into consideration.
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
Dirk_Hendrik wrote:What I should do is press print screen a few times next time and post the shots including comments...
That would be amazing (presuming you're serious, I know you're pretty dry)....
I'm personally strictly vero at the moment, but i'm eager to get started on some proper pcbs, especially now there seem to be some cheap-ish smallscale pcb fabrication online now. So far, I've opened Eagle a few times.... then closed it again.
Duckman
Has thanked: 320 times
Post by Duckman »
Here's a good reference
Fabricating_Printed_Circuit_Boards.pdf
(1.62 MiB) Downloaded 186 times
Aharon
Has thanked: 24 times
Been thanked: 5 times
Post by Aharon »
RG Keen has a book on PCB design at GEOFEX.
Aharon
CodeMonk
Has thanked: 13 times
Been thanked: 54 times
Post by CodeMonk »
As said by everyone else, practice, practice, practice.
How I approach it is to stare at the schematic for awhile, mentally placing components on a PCB.
Considering component size and purpose.
I usually go from left to right with the schematic.
I also try to keep in mind how I want the last few parts to be placed.
When I lay down the first component, I try to imagine where the next 3, 4, 5 or more components go.
As I add more components, I continue doing this as well as back-tracing the circuit 3, 4, or 5 components as well.
I takes a lot longer doing it this way, but my success rate is much higher this way, for me at least.
Post by DrNomis »
No worries, we were all newbies once, including myself.....actually I miss those newbie days..... :thumbsup
PCB designing is kind of an artform, like music.... :thumbsup
DrNomis wrote:.....actually I miss those newbie days..... :thumbsup
Hmmmm. preps the joy of discovering something new.....
but the frustration.... the endless frustration. Naah not that again :blackeye
Duckman
Post by Duckman »
Dirk_Hendrik wrote:but the frustration....
Thanks to that, you're a happy builder now 8)
