Inspired by Dirk Hendrik's Real Tube Screamer pedal project elsewhere in this section, and after reverse engineering the B K Butler Tube Driver, and noting some similarities, i have designed a brand new design for a REAL tube drive pedal, housed in a Hammond (or equivalent NSC) 1590BB case. There are three circuit boards - a mother board that holds the footswitch, input, output and AC power supply sockets; a small board to hold the 12AX7 tube and it's passive components, and a board to accomodate the driver dual op amp and three control knobs.
The three boards are solder pinned togaether and form a very strong structure to hold the tube and controls etc. There is only one wire to connect the board to the chassis earth.
I gave my finished prototype a run, last night at practice, and was complimented on my great guitar sound (not playing ability mind you
I will be building these on a one by one basis as time permits, and the price will be US$330.00 plus postage etc. (power supply not included)
However, you can build your own if you would like to, because I shall be placing the complete design layout, PCB, chassis, and artwork details exclusively for all registered members of the freestompboxes forum.
I may be able to supply board kits on request, but have not worked out prices as yet, because this is a very new project.
The only other piece of equipment you will need is a suitable 16vAC power supply - there are many 16vAC 1.5A types available as burglar alarm supplies - just buy one of these and solder a 2.1mm dc socket on the wires -
I will be posting full details in the next few days - stay tuned
bajaman wrote:Here are some pictures of a complete Baja Real Tube Overdrive pedal - minus the case, which is awaiting powdercoating![]()
This is a fully operational unit (although it hums a bit outside of a metal case), just completed today and worked first time i plugged the 16vAC power pack in to it.![]()
My apologies for the poor quality etching - the board material was getting a little old (like me). The led indicator is attached after mounting in the case by two flying wires through the holeabove the middle control pot.
Apart from this the only other wiring is to attach the board earth to the chassis through the green wire connected to the footswitch.
enjoy![]()
project details to follow very soon - i have to go to a birthday party now though and get drunk![]()
more tomorrow, when I awaken.![]()
bajaman wrote:Here we go - this should get you started - PM me for higher res artwork if required![]()
enjoy
bajaman wrote:some construction notes:
The status led is inserted in the top of the case and attached by flying leads through the hole on the circuit main board. The long pin wire on the led connects to the vacant pad that connects to the 7815 regulator IC, the other lead connects to the pad which is connected to the 1k5 resistor.
The input and output sockets were purchased from Aron at DIY Stompboxes store - good value for money![]()
I used 30 amp fusewire for the wires connecting the three boards - note the wire is connected to the solder side of the tube socket board and the component side of the control and driver board.
The 10k and 47n series connection is connected to the solder side of the tube socket board.
Lightly file and tin the footswitch, before attaching the green board to chassis earth wire.
The 7915 regulator needs to be raised at approximately 45 degrees to prevent the metal tab from contacting the solder side of the control board - you may have to adjust the 7815 regulator sideways to avoid contact with the solder side of the control board as well.
When attaching the footswitch, raise it slightly above the circuit board - do not push it down hard against the board, otherwise you will not get enough thread through the top of the case to attach the mounting nut.
I tinned the board first before I attached the three control pots. i soldered these by soldering from the top and sweated the solder between the pot wafer and circuit board.
No MOJO parts were used in the construction of this project![]()
I used metal film resistors and MKT polyester 100v capacitors.
The solder used was Ersin Multicore Savbit 60/40 crystal Flux non rohs too.![]()
My thanks to Dirk Hendrick and B K Butler for their inspiration in the creation of this project. Please feel free to ask any relevant (or irrelevant) questions regarding this project
bajaman wrote:Well - I have tried putting tubes in 1590BB boxes many years before, but I guess it was the Real Tubescreamer project by Dirk Hendrick in this section of the forum, that inspired me to use a small sub board for the tube.How did you come up with the idea to do the tube like you did
Also, I had just extensively modified a Behringer VT911 Vintage Tube Overdrive, after reading that it too was based on the B K Butler or Chandler Tube Driver pedal - the Behringer has a small sub board for the tube too. Before you rush out and buy the Behringer though, you should know that it is the worst sounding piece of shit distortion pedals I have ever heard![]()
it runs off 9v DC, which is 3.6v DC less than what the tube heaters require, and the design of the tube section is nothing like the B K Butler or Chandler - it bears an uncanny resemblance to the original patent or Jack Orman's Tube Driver schematic.
My design is not based on the patent or Orman's schematic![]()
i used to use Protel autotrax program, many years ago, but because of lack of practice, I have almost forgotten how to use it properly, and the latest version is way to complicated for a simple guy like me - who needs 10 layers of board etc.how did you go about creating the pcb after that?for stompbox pedals.
So - i use a graphics program - CorelDraw version 11 (I have version 13 or X3 too, but version 11 works fine for me).
With Corel, I can design and draw my own pads and lines etc, curve them, or incline them at any angle - not just 45 degrees.
I then can generate parts layouts, front panel labels and chassis drilling templates directly from my PCB drawings - helps enormously with lining things up correctly.
After seeing Dirk Hendrick's Real Tubescreamer, i thought wouldn't it be easier to mount the tube board direcly to the main board without the need for any offboard wiring - the control board with the driver IC connects to the small tube board as well, which forms a reasonably rigid structure to keep the tube horizontal and therefore parallel to the mainboard.
I guess using a drawing program like CorelDraw allowed me to make easy measurements to ensure that all the connections between the boards lined up correctly. I etch my own boards, go cross eyed drilling them and then insert all the components and solder by hand - i will not by outsourcing with this project - hand built by me alone![]()
ps: PM me if you do not feel up to building your own - I will happily build one for you for a reasonable price
bajaman wrote:Some pictures of a finished pedal - the customer chose the name and colour![]()
Important: I have found that there is a difference in metal thickness between the Hammond and NSC equivalent cases ( available from Pedal Parts Plus).
Originally i took measurements from the cheaper NSC case which has a much thinner walled and top panel thickness than the Hammond.
When i tried to fit the assembly in a Hammond case, I found that i could not fit the bottom panel. So, after a wee bit of cursin' I dismantled and trimmed the tube and control boards ( I had to remove at least 1.5mm) i refitted the boards and this time as you can see the case lid was able to fit properly.
I will redraw these boards for those who wish to use Hammond cases, but i would strongly suggest usingf the cheaper thinner NSC cases if you want to use the existing board layouts.
Sorry for any inconvenience.
bajaman wrote:Hello again![]()
Please use the following PCB and Layout artwork if you intend to use the Hammond 1590BB case
If you are using the NSC equivalent 1590NS case then please use the original artwork posted earlier.
bajaman wrote:Hello folks - sorry for the delay - I forgot![]()
here is the schematic at long last.Cheers
