I want to upload images but it says that archives are too big.
Bypassed sound OK
tube gets red when I plug the PS (it remains red when the effect is bypassed)
33k/ 2w resistor gets hot (not burning hot but hot)
status led working OK , (when I touch the track that goes to the long terminal of the led, it turns on.!)
Pedal works bypassed even unplugged and even unplogged when I turn it on, it turns on ! (I mean the status led turns on..
Well may be that's because of the electrolitic capacitors.)
Only little bit of hum noise can be heard when the pedal is on but, no guitar signal.
I suspect that the tl082 might be the problem, as i only own one , i can't tell.
First time I turned it on , a 470uf 35v dropped some juices, may be it got damaged but, if this one gets damaged, the pedal should be turning on and just get muted.?
Hope you can help me, thanks .
