You definitely have a fault condition around the dual opamp and it looks to me like you have a short between pin 3 and pin 4, because pin 4 is the correct voltage - pins 1, 2 and 3 should measure 0 volts DC.
Not sure how you are measuring the op amp but the correct pin order is 1 2 3 4 down one side and then 8 7 6 5 down the other side (pin 8 directly opposite pin 1, pin 7 directly opposite pin 2, pin 6 directly opposite pin 3, and pin 5 directly opposite pin 4
The op amp may still work but you definitely have a direct short between pin 3 and pin 4 - use the ohms x 1 setting on your meter ( without the power supply connected of course) and I think you will find these pins are connected together either through a poor etch or solder bridge etc.
If you manage to remove the short it should work correctly and won't sound bassy on bypass - if you still get +15v DC on pin 1 then you will need to replace the op amp.
Let us know what you find
