YesDo they come pre-cut?
Steve
yes pin 4 should have -15v on itthese voltages are kinda screwy aren't they ?
yes to both questions - but do try to use the 16vAC supply if possible - you may have to increase the large dropper resistor that feeds the tube heaters if you use a higher voltage transformerHi Steve, is your power supply a simple transformer transforming the standard house volage from 220VAC to 16VAC (non regulated obviously - it is only transformer). I have one so I am looking to use it simple connecting cables and printing 3d case for it instead of buying one. They are not that cheap here in UK. Reading your comments it looks like I can use 18V one ensuring that capacitors are at least 35V. Correct?
Cheer, Srdjan
Srdjan,stojanos wrote:Hi Steve, is your power supply a simple transformer transforming the standard house volage from 220VAC to 16VAC (non regulated obviously - it is only transformer). I have one so I am looking to use it simple connecting cables and printing 3d case for it instead of buying one. They are not that cheap here in UK. Reading your comments it looks like I can use 18V one ensuring that capacitors are at least 35V. Correct?
Cheer, Srdjan
