When turned on the led is light but the signal is cut totally and I can only hear some scratching when I turn the tone knob... the other 2 give no reaction at all. there is no noise or anything going to the amp.
it turned out that the 3 resistors are simply missing from the kit. I assumed when I ran out of parts that I was finished.
thanks for the help, Duckman
If you have 390k or 510k, it'll not be exactly the same, but just a little difference: 390k will reduce gain and 510k will rise it.
Not big deal, just to make the beast breathe.
I don't have 3 of the same value, but I contacted them and they will send the missing ones ... I think is time to order a big bag of resistors for cases like this one.
