TL061CP or TL061ACP
antjessop
Post by antjessop »
I'm going to build an MXR Micro Amp after successfully building my first pedal, an LPB-1. However, I've never dealt with opamps before.
I checked at the local store and they have a TL061CP and a TL061ACP on offer. What is the difference and which should I choose?
Thanks in advance,
Anthony
blackbunny
my favorite amplifier: Fender Blackface
Completed builds: Lots of mods to lots of pedals
Has thanked: 271 times
Been thanked: 105 times
Post by blackbunny »
The TL061ACP has lower input offset voltage, input offset current and input bias current than the TO061CP, which makes it technically a higher grade version.
Shouldn't make much difference in a 9v effect though. Why don't you socket your pc board and try both?
