3W tube power amp (my design)
Posted: 25 Jun 2012, 14:47
I've planned to build this thing for over a year, but couldn't find time. Finally, I had few weekends to dedicate and it's all done.
Output tubes are biased with LEDs, 6 white and two red, wired in two parallel arrays to make sure they can take the current.
I turned out exactly as I planned. It's super clean. There's a boosted and "all tube" input. Boosted can get handy when playing with guitar straight into the amp because without the boost it can get loud about as the TV. When using a preamp or hot pedals there's no need for the boost (unless you want to drive the output more) so unboosted input is fine.
You can find pics and schematic here http://diy-fever.com/amps/3w-tube-power ... db40434531
I'll try to record clips soon.
Cheers
Cheers
