Looks like it shares the same PCB with the malekko wolftone helium since there are unused holes and traces on top side of the PCB. No components hidden backside.
From what I found :
Entropy : B 500 K Drive : B 50 K Vol : B 50 K
Ic : RC4558P from texas instuments
Diodes 1 to 14 : 1n4148 D15 : 1n4001
The transformator is marked : TM117- R 11415 I suspect it to be the same as in the Octavia
R1 : 510 R2 : 1K R4 : 100K R5 : 100K R6 : 470K R8 : 1.2M R10 : 75K R13 : 10 K R14 : 10K (I miss some resistors numbers on the Pcb
C1 : 1n box c2 : 1uf box c3: 100n box c4: 4n7 box c5: 10n box c6:1uf box c7: 100uf pola c8: 100uf pola c9: 47uf pola
Tell me if you need something about it, I'll take a look
