Schematic:
Click HERE!
The next offering in the "L'Overdrive de la Révolution" Series is here! Trois!
It's a light overdrive/boost effect (There isn't a great amount a clean headroom here though) utilizing a Jfet stage running into some germanium clippers all cascaded into a common Mosfet gain stage. It's a very dynamic and resposive circuit, I wanted it to be controllable from your guitars volume and tone pots, goals which it definatly scores!
Inspiration for the front end JFET section was taken from the great runoffgroove "Omega" project which is a great versatile booster project which really is worth a build. I loved the way the Omega's "Range" control worked and wanted to see this put into use in an overdrive circuit, a few simple ideas later and here you have it: "L'Overdrive de la Révolution Trois".
There are loads of notes on the schematic image identifying possible mods and changes. A great one is the alternate clipping setup - which I am actually currently using in my build
Give it a try on breadboard, it's a super easy build and a great sound to boot! You won't be dissapointed
