Danelectro PB & J mods anyone?
minor7th
Post by minor7th »
Hi, when looking at another thread, there was a comment that the Danelectro PB&J was a good candidate for mods.
There's nothing here that I can see- I can't even find the original comment. (I must be getting too old to use this technology :P ) Does anyone have any suggestions on where else to look?
Thanking you. 8)
m7 [smilie=vibes.gif]
OrionManMatt
my favorite amplifier: AC30
Completed builds: BB Preamp, volume pedals, tap tempo boxes, etc.
Been thanked: 16 times
Post by OrionManMatt »
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
These are the experimentalistsanonymous.com mods, they are really great. It was one of the first FX mods I ever did and I used that pedal for ages. It only died when I spilt beer on it! I'm about to create my own super delay pedal to rehouse in the wah shell I placed my PB&J into, Zvex probe style control + Sequencer?!?
PB&JMods.pdf
(59.52 KiB) Downloaded 430 times
I am Klon.
minor7th
Post by minor7th »
Many thank yous, kind sirs! :applause:
dread pierat
my favorite amplifier: 2204
Post by dread pierat »
I opened a PB&J yesterday, and the new version is quite different.
The delay line (PT2395) and memory (41256) are both near or at the end of their lives, and dano replaced these with an ATmega48 and ISSI 1024 x 8 ram.
The buffer board now runs at full battery voltage, compared to 5V in the old unit.
Stay tuned for pix.
dread pierat
guts :horsey:
dano pb&j io and buffer
dano pb&j main board flipside
dano pb&j main board macro
dread pierat
the connectors on the main board are:
VIN (signal from input buffer)
VCC
GND
VOUT (signal to output buffer)
top of io and buffer board
backlit awesomeness
backlit awesomeness
connectors close-up
connectors close-up
dread pierat
The upper part (shown in red) is the human interface. The Philips 74HC237D pulses at 50Hz, checking the two foot switches, the 3 potentiometers, and lighting the red/green LED if the unit is on: red is the short delay modus, and green is long.
The light blue part is the analog part (literally!) The chip is a custom (I guess?) Analog Devices unit, marked "71031 74111 #842". It appears to be an ADC/DAC with serial interface.
The memory and its housekeeping are shown in yellow. Theres two TI 74HC373 and the big one is the ISSI 1024 x 8 RAM.
Then there's the Atmel ATmega48, and in the middle are some headers for testing and whatnot.
annotations
annotations
RylanW
Post by RylanW »
Does anyone know if it is possible to perform the "gambit mod" on the new ATmega48 version of this pedal?
I was prodding around at shorting some resistors but couldn't find this result yet:
aishabag23
Has thanked: 85 times
Post by aishabag23 »
RylanW wrote:Does anyone know if it is possible to perform the "gambit mod" on the new ATmega48 version of this pedal?
I, too, would love to know if the gambit mod is possible on the newer PB&Js... So this is a BUMP, I guess!
Loe Sounds
