Diode and capacitor in voltage protection circuit
fishfude
Has thanked: 37 times
Post by fishfude »
Hi Folks,
In the image below, I believe the diode and capacitor are there to protect the circuit from too high a voltage coming from the DC power source (correct?). My question is what is the exact purpose of the diode and the capacitor are, and why were they specifically chosen?
http://imgur.com/j1hm9
Many Thanks,
ff
CHEEZOR
Has thanked: 42 times
Been thanked: 47 times
Post by CHEEZOR »
Please wait for someone else who is more knowledgeable to reply, but I believe they are for reverse polarity protection which is meant to save your circuit in the event that someone hooks up the pedal with the polarity opposite what it should be.
Duckman
Has thanked: 320 times
Post by Duckman »
Cheezor is right: only a reverse polarity protection, but just the diode.
The cap is for power source filtering... but 22uf? It looks a little "short" since any chinese wall wart can have a 1000uf inside
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
More like decoupling rather then filtering.
CHEEZOR
Post by CHEEZOR »
Duckman wrote:Cheezor is right: only a reverse polarity protection, but just the diode.
Oh yeah. I totally spaced that. :oops: Thanks! :thumbsup
Duckman
Post by Duckman »
FiveseveN wrote:More like decoupling rather then filtering.
Like in a voltage divider? Mmm... maybe
FiveseveN
Post by FiveseveN »
http://en.wikipedia.org/wiki/Decoupling_capacitor
There's a duplicate thread on the other forum and another tangent discussion that provides more concise answers.
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
I think this is semantics of our favoured terminology. Decoupling, power filtering, ripple reducing, the cap can be performing all of the above.
The real mystery is why builders keep using parallel protection diodes without a fuse so that under reverse polarity the diode can take a chunk out of your board.
Duckman
Post by Duckman »
FiveseveN wrote:http://en.wikipedia.org/wiki/Decoupling_capacitor
Tanks. First line of the mentioned article:
This article is about the use of capacitors to filter undesired noise from power supplies.
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
IvIark wrote:I think this is semantics of our favoured terminology. Decoupling, power filtering, ripple reducing, the cap can be performing all of the above.
No mystery here. Boss did it that way because their 1A diode would get hot (but not burn) when hooked up backward to their 1A PSU. No fuse necessary. Boutiques and diyers copied Boss because... Er, tradition, I guess.
