Help with schematic needed
I'm trying to build a Pearl ph-01 phaser from a schematic diagram (below) and I need a bit of help to pull the whole thing together. There are arrows pointing up and arrows pointing down and I'm trying to figure out in what sense the two are meant to be kept separate, i.e if the arrows pointing up are all connected to +ve where are the arrows pointing down supposed to be connected to?
- Dr Tony Balls
from the DC jack on the left follow a bit to the right just past Q3 and you'll see VCC point up and something else pointing down (i cant read what it says because of the blue circle). Those are your two power connections. Connect all the red circles to VCC, and all the blue to the other one.
Presumably there are additional power connections to lugs 4 and 8 on each of the op amp chips which are not shown on the schematic, is that also true for the hex inverter ?(ic4)
