Bottle Rocket as stage one in 5E3
wrnchbndr
my favorite amplifier: Fender Twin
Completed builds: A series of modified 5E3s, 5E6 and 5F8s in exotic hardwood cabinets. Too many handcrafted guitars to list. I play around with stompboxes now and then. I've built a fair number of one off specialized instruments and a few for people with special needs. Everything is custom and I never do the same thing twice.
Location: Mid New Jersey soon to be eastern PA in the woods
Post by wrnchbndr »
Has anyone here actually built a bottle rocket? Its a question of a correct schematic and I have found a couple with subtle differences. On one in particular, the tone stack and the volume control pots seem wrong and this is the schematic that looks like its a Mesa Boogie Service document. In another post somewhere, somebody has said that Mesa Boogie deliberately puts errors into their schematics to prevent cloning and I'm wondering if anyone has gone through this and been successful. I have a 5E3 that I built a few years ago with 6L6s and its sort of limited in its tonal pallet. I'm thinking that I can install the bottle rocket circuit in place of the first stage. I've already changed the parallel inputs that go into V1 into a series circuit so one side of V1 acts as a gain control feeding the other side of V1. It works but the preamp distortion is overly harsh -- I could tinker with this but the bottle rocket is a more direct aproach to getting some true flexibility. I have plenty of headroom for current and it shouldn't be hard to get the correct +Vs. I have all of the parts on order and I've plotted out a turret board that is easily small enough to fit into the available space of 5E3 chassis using Express PCB.
Thoughts - Recomendations???
The otters threw me out because I was too messy.
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
You're talking about the Bottle Rocket V1 pedal, right?
http://www.mesaboogie.com/Product_Info/ ... ocket.html
wrnchbndr
Post by wrnchbndr »
Yep, I'd like to find out if anyone has built one and knows about the schematic and the errors on some of the schematics I've seen on the internet. I have found at least two schematics with differences in the output section. I'm fairly sure that one is clearly wrong -- or, they might both be wrong??? I'm just looking for advice on the pedal schematic. Its easier to debug when using correct info to begin with. The schematic for the power supply is not needed.
I originally posted this in the pedals section but it got moved here.
phatt
Been thanked: 338 times
Post by phatt »
Hi wrnchbndr,
I doubt schemo mistakes will be the headache.
The noise/buzz/hum will be the real enemy. winky.
Unless great inroads are made in layout and heater setup you are likely going to end up with a very annoying circuit.
The rocket has DC heaters and this will help but my guess is it will still be problematic.
Phil.
