Mad Professor - Electric Blue Chorus
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
I just remembered, I snapped these pics a while back. Once I have some time and it's light outside, I'll snap some better pics if there is any interest. Doesn't look like an easy trace.
It has a Pt2399 and a Ne570 D compandor as well as a TL061CP and two JRC5534 DD. Two 78L05 are also in there. The thing is very well build, two pcbs that are connected via a cable strip. One holds the pt2399, compandor and the pots and the other holds some opamps, the jacks and switch. I wonder what the second 5v voltage regulator is for. the pt2399 only needs one, the opamps dont and the ne570 needs at least 6v.
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Seiche wrote:I wonder what the second 5v voltage regulator is for.
More current? :hmmm:
LaceSensor
Has thanked: 57 times
Been thanked: 277 times
Post by LaceSensor »
Here was me thinking it would be analog... :whappen:
newly
Post by newly »
A PT2399 generated chorus?
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
newly wrote:A PT2399 generated chorus?
it's not unheard of
https://www.freestompboxes.org/viewtopic ... 13&t=10276 :thumbsup
Seiche
Post by Seiche »
LaceSensor wrote:Here was me thinking it would be analog... :whappen:
analog bjf design? get outta here! :lol:
culturejam
There are at least three that I can think of over at DIYstomp.
LaceSensor
the eartQuaker devices chorus is also PT2399 based.
my friend has it but he is in London so I cant make gutshot..
it sounds like shit anyway.
Has thanked: 218 times
Been thanked: 857 times
That's the easy part.
Now,
Companding is usually used to inprove signal to noise ratio in delay lines where the sampling gets real shitty. Read: Analog delays, When the sampling rate is higher the signal to noise ratio stays better and companding... is for wankers.
Except there is a case where sampling is not even an issue and the delay times are really short. That's the Ibanez PH99.... which uses a compander... uberwanking..
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Now,
Would that be a Wanking Panda ?
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
fakcior
Been thanked: 20 times
Post by fakcior »
Hello,
I received from my friend couple of pics with guts of that beast. It looks like pretty immense design - PT2399 with NE570 compander and 3 opamps (TL061 and 2x 5534). Hope pics will be helpful. I'm attaching them in zip archive.
Mad Professor - Electric Blue Chorus gut shot 12
Mad Professor - Electric Blue Chorus gut shot 11
Mad Professor - Electric Blue Chorus gut shot 10
Mad Professor - Electric Blue Chorus gut shot 9
Mad Professor - Electric Blue Chorus gut shot 8
Mad Professor - Electric Blue Chorus gut shot 7
Mad Professor - Electric Blue Chorus gut shot 6
Mad Professor - Electric Blue Chorus gut shot 5
Mad Professor - Electric Blue Chorus gut shot 4
Mad Professor - Electric Blue Chorus gut shot 3
Mad Professor - Electric Blue Chorus gut shot 2
MP EBC.zip
Gutshots
(1.17 MiB) Downloaded 566 times
rocklander
inspired by the lil angel?
mmolteratx
Has thanked: 93 times
Been thanked: 618 times
Post by mmolteratx »
Knowing Bjorn, the 5534s are the input and output/mixer stages since they're rail to rail and there's only a single supply line. The TL061 is the oscillator, and the delay line is companded. Wouldn't be terribly surprised if the basic method of chorus is similar to that of the Little Angel, but the rest of the circuit is likely fairly different.
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Lots of pictures here: viewtopic.php?f=7&t=21965
But still no trace...
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Now,
That may be the case, but the PT2399 tends to go into clipping very easily. If you compress / limit on the way in and expand on the way out, you can get all the effect without the risk of getting that nasty distortion.
roseblood11
I would really like to see this one retraced.
Not to build a clone, but maybe to learn s.th. to make an improved version of the "Dimension-P" chorus, which is based on the PT2399 as well...
BJF
Been thanked: 68 times
Post by BJF »
Hcvlled my localo there
Oh yes I wanted to use a compander to lower noise of the design I made and you might get a laugh ot of it that I called my local submarine enginer and discussed
superhetorodyne modulators and I banged my head against the garagewalls until it dawned on me from radio school that yes you can current modulate...
The one thing that bugs me isthat 35 years of learning memories still take hours to come.
F... yeas I recall being young and the eagerness :horsey:
At your service
BJ
BJF
Post by BJF »
roseblood11 wrote:I would really like to see this one retraced.
Hi there,
Right what would you like to learn?
At your service
BJ
designer of Electric blue chorus
BJF electronics
Sweden
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
I'd guess to see how you implemented the compander with PT2399. That is the thing that i haven't seen done too many times.
+m
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
