Clock of Tone 50 - Modified COT50
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
Thanks for that MC. Yeah, 47n is correct. I would strongly recommend you socket that cap though - it needs to be tweaked for different amps. The amp I was testing through was quite poor and pretty bright.
Is it OK if I post your layout on my blog, of course, full credit will be given?
I am Klon.
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
briggs wrote:Thanks for that MC. Yeah, 47n is correct. I would strongly recommend you socket that cap though - it needs to be tweaked for different amps. The amp I was testing through was quite poor and pretty bright.
Good to know. It seems like a "large" cap...thats why I asked.
Sure, no problem ! :)
briggs
Post by briggs »
Thanks Andy. I'll put it up, I just tried this thing with mosfets. It's a more "modern" sound, much more headroom and even greater dynamic range! I added a blend pot to got between the two and it was pretty usefull. It's just a 10kB pot blending between the two diode sets - 1n270 and BS170 mosfets, it allows you to dial in a bit of both, an interesting and very usable sound.
I am Klon.
Blues Lyne
Post by Blues Lyne »
briggs wrote:Thanks Andy. I'll put it up, I just tried this thing with mosfets. It's a more "modern" sound, much more headroom and even greater dynamic range! I added a blend pot to got between the two and it was pretty usefull. It's just a 10kB pot blending between the two diode sets - 1n270 and BS170 mosfets, it allows you to dial in a bit of both, an interesting and very usable sound.
Great idea, more versitile than the switch I used. I really like to sound of the mosfets (I think mine are 2N7000's) but sometimes wish I had a little more break up.
briggs
Post by briggs »
Yup, you can use the blend control to dial in just a little more fizz than the mosfets provide. I imagine it would be a good control to have as an internal trimmer. No need for it to be external really. Unless you want super versatile!
I am Klon.
erikm5150
Post by erikm5150 »
Cool looking circuit... I'm planning this for my next build...
Here's a vero layout that I'm planning to use...
I'm still new to this, so please let me know if there are any mistakes:
allmonochrome
Post by allmonochrome »
erikm5150 wrote:Cool looking circuit... I'm planning this for my next build...
have you verified this yet? i really wanna build it :D :oops:
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
This sounds like a great idea, but I'm a little shaky on how to set that up. Could you give a little more detail on how to wire up the blend control with diodes?
Also, why a 10k pot?
Thanks for the help.
briggs
Post by briggs »
From Jack Ormans AMZ. There is a vero layout from Torchy on my blog 8) Don't bother witht he 1k resistor shown here. I used a 10kB pot bcause it worked the best 8)
I am Klon.
culturejam
Thanks, briggs!
That's pretty close to what I was thinking in my head, but it's nice to see a small schematic.
Deaj
Post by Deaj »
I've had some time to play with this circuit since building it and I have some observations to share. It's very similar to the COT-50 blue. With 1N270 Ge diodes its a little closer to unity gain when compared to the COT-50 and has a bit more low end / more balanced EQ. It also clips the signal a bit more along the entire sweep of the Structure (bias) control as compared to a COT-50. The Nature (tone) control is very useful. The first 20% of its sweep allows one to adjust the bass response effectively. The rest of the sweep mostly affects the top and upper midrange. The Structure control does more than just add grit. As it's turned up it gradually introduces a 'sag' like effect to the attack when the strings are struck hard, much like a low wattage tweed or early tube rectified Marshall. Cool circuit! Thanks Briggs! :D
Blues Lyne
Anyone else notice that when the "bias" knob is turned to 3:00 or beyond, the tone gets thinner? It's either losing bass or gaining high end. Mine sounds nice and full up until just before 3:00. Just curious if it's just a fluke with mine, or normal for the circuit.
Torchy
Post by Torchy »
What "bias" knob ???
briggs
Post by briggs »
Why thank you deaj!
The gain control; on an actual COT50 it's called bias. The structure (bias) and nature controls are very interactive - they do affect the effect of one another depending on how they are set. I think it's an interesting and useful interaction though, it allows for many more tones to be created 8)
I am Klon.
Blues Lyne
I wan't thinkin'. I should have posted that in the COT 50 thread, since I haven't tried the nature control yet.
premiumplus
Post by premiumplus »
Thanks briggs, great circuit. I built mine a couple of weeks ago but just got it boxed up today. I've been playing it and it's going on my board for the weekend at least.
I'm going to build all these...
Vinyl rules.
briggs
Post by briggs »
8) Glad you like it. I've not had chance to test one with my new "suprono" yet! Can't wait to though!
I am Klon.
culturejam
Has anyone verified the pcb layout by Mr. Cowbell?
I figured I'd go ahead and make the pcb and give it a try. I don't mind being the first to test it, but if someone else has built the COT50 from this layout, I'm interested to know how it went.
Thanks.
jzilla
Post by jzilla »
what range of values would you suggest to experiment with? thanks!
-j
briggs
Post by briggs »
Any range from 1n to 100n, just keep playing with it until your happy...
I am Klon.
