MXR - Badass Modified Overdrive  [schematic]
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
I just bought a MXR Badass Modified Distortion to trace, so here are some PCB pictures and a schematic.
I have traced the full effect but as usual I don't bother with the fet bypass and led indicating lights.
first the PCB pics. There are two PCB's one has the main circuit and the second has the control pots and is connected to the main PCB with a ribbon cable.
PCB top with the pots
PCB bottom with the pots
MAIN PCB bottom
Main PCB top
Main PCB top with hardware removed for easier tracing
Ice-9
Post by Ice-9 »
Here is the schematic I have traced and component value list, I have just hand drawn it but it should be readable.
MXR Badass Modified Overdrive circuit description.
Ok so here it is, Not a lot different to the zakk Wilde ZW44, it starts with the same input buffer based around Q2 then into an opamp clipping section with assymetrical clipping diodes in the feedback loop. The next opamp section is a tone control with the addition of R6 which is switched to 1/2V (bump switch).
The only real difference is in the next opamp section which is a 100hz boost/cut build around a gyrator circuit.
Schematic
Ice-9
Post by Ice-9 »
And the component values.
MXR Badass Modified Overdrive - Component values
StefSamy
Completed builds: TS9/808
Treble booster Gé
Zvex Fuzz Factory
Dr Boogey
+ Mods on ProCo Rat, BOSS CS3
Post by StefSamy »
Very good job for this nice overdrive, man :thumbsup :applause:
StefSamy
Treble booster Gé
Zvex Fuzz Factory
Dr Boogey
Post by StefSamy »
Sorry but what is U2?
Is it a 33178 and in fact U1 and U3 are "duals" 33178? :oops:
StefSamy
Treble booster Gé
Zvex Fuzz Factory
Dr Boogey
Post by StefSamy »
Sorry again, for multi posting, but I don't find how to edit my posts....
- is the part with Q1,3,4,5,6 and R18,22,23,25 a buffer part?
If so, if we build the stompbox in truebypass mode, we don't need them, but do we need C13 that is listed in your LoC? :hmmm:
Ice-9
Post by Ice-9 »
StefSamy wrote:Sorry but what is U2?
U2 is i the power rails and is just there for polarity protection, so to build a clone just use standard power and polarity.
Yes U1 and U3 are both 33178 dual opamps.
Ice-9
Post by Ice-9 »
StefSamy wrote:Sorry again, for multi posting, but I don't find how to edit my posts....
None of the above parts are needed as you say, they are all just part of the bypass switching and led indicators. If you build this with true bypass switching.
also C13 is not needed. ( It's only in the LOC because I wrote it down before realizing and wasn't goin to right the lit out again :slap: )
StefSamy
Treble booster Gé
Zvex Fuzz Factory
Dr Boogey
Post by StefSamy »
OK, that's clear with your other reply too, thanks for all :)
I was wrong with my post, it was R24 and not R22 that is not needed (i write this for other readers :) )
Ice-9
Post by Ice-9 »
If i can get round to it I will try and do a layout for through hole components for this. Just a bit pushed for time at the moment.
StefSamy
Treble booster Gé
Zvex Fuzz Factory
Dr Boogey
Post by StefSamy »
A VERO, YES, nice job :)
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
I misread R13 and R17, so the input resistor should in fact be 10K and not 240K. Someone is currently building this, so i'll update the layout once i hear back from him.
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
mirosol
Post by mirosol »
The edit time of the posts close up so fast :)
One of our blog's trusted readers just notified us that the layout is now verified. And the wrong resistor value is also fixed...
Bill_Mountain
Has thanked: 44 times
Post by Bill_Mountain »
Those 2 separate eq stages seem redundant. Couldn't the tone and 100Hz control be combined in the same network like a graphic eq (with a peaking low and shelving high)?
LightandLIfe
Post by LightandLIfe »
Been searching far and wide and you guys seems like you guys can help. My Custom OD only works with the Bump switch engaged. When dis engaged, no sound comes out? Can anyone point me in the right direction?
bunyaman
Post by bunyaman »
Hi! What is VS1 and VS2 on a schematics?
bunyaman
Post by bunyaman »
My PCB. Layout was edited after making PCB
theroan
Post by theroan »
Thanks for this!
p88wright
Post by p88wright »
Hi ICE-9,
I just wanted to check if the values for the Capacitors were measured in-circuit or did these parts get removed and measured? Reason I ask is that some of the values seem a little out when I did a couple of quick calcs for the tone and 100 Hz filter networks
Thanks,
Phil.
Ice-9
Post by Ice-9 »
p88wright wrote:Hi ICE-9,
Thanks,
Phil.
Yeah, they were measured in circuit which can account for odd readings.
