Power Socket
AlexBellamy
Post by AlexBellamy »
Hey guys, I'm putting together a treble booster as seen here: http://diystrat.blogspot.co.uk/2011/05/ ... reble.html
I'd like to have the option of powering it by battery or an adapter, so I'm going to follow this diagram to wire it up: http://diystrat.blogspot.co.uk/2009/06/ ... fects.html
I've never actually done this before though, so just to make sure I get it right, would this socket be the right one to use? Its the sixth item down on this page: http://www.bitsbox.co.uk/connectors/power_con.html
Would this be suitable? Thanks very much for any help you can give me!
Dr Tony Balls
Been thanked: 170 times
Post by Dr Tony Balls »
Yes, that socket will do you just fine. Ive built hundreds of builds using the very same one.
AlexBellamy
Excellent, thanks very much!
AlexBellamy
One more thing, should I get the 2.1mm or 2.5mm socket?
Thanks :D
Dr Tony Balls
2.1mm
