Gut shots yoinked fromhttp://www.etsy.com/listing/79352156/mc ... ratron-vtf
- worth checking out the description of the pedal there as well - with 11 knobs and a bunch of switches there's a lot going on. If I remember correctly it is an optioned up Brassmaster/Muff thing. It's possible to get horrible sounds, awesome sounds, normal sounds, whacked out sounds, gated, sustainy... everything. And it's surprisingly easy to dial in once everything makes sense. The wiring on the pedal I got to test was at least as clean as the following pics.
Schem courtesy of McSpunckle's post on ILF - http://ilovefuzz.com/viewtopic.php?f=15 ... ic#p348155
Good luck with the offboard wiring...
