[Tips & Tricks] Perfboard Building
Posted: 26 Feb 2008, 14:24
by drmathprog
I'm inspired by the Eternity and King of Tone perfboard projects. Can someone point me to a tutorial or suggest techniques for soldering a perfboard project? Specifically, I'm not clear on how I can solder the components on one side to the wires on the other side.
Re: Perfboard Build Tips?
Posted: 26 Feb 2008, 21:11
by ieatyouforbreakfast
don't cut the leads to the components and use the extra lengths as traces.
Posted: 26 Feb 2008, 21:19
by drmathprog
Thanks. Seems obvious, but it didn't occur to me until I read your post.
Posted: 27 Feb 2008, 05:51
by Dave Simpson
Posted: 27 Feb 2008, 14:34
by drmathprog
That's perfect; I don't know why I couldn't find it! Thanks!
Posted: 29 Feb 2008, 03:41
by Alex C
The
Tweak-O project has hole-by hole instructions, and shows both sides of the board at several stages. It was my first build, and I was very fortunate to have this project as a guide.
-Alex
Posted: 29 Feb 2008, 07:30
by ubersam
I create a layout for a pcb then use that as a guide when building on perfboard.
Posted: 29 Feb 2008, 11:35
by drmathprog
Thanks Alex. I've never seen those push in terminal posts before. Where did you find those?
Posted: 29 Feb 2008, 22:48
by Alex C
drmathprog wrote:Thanks Alex. I've never seen those push in terminal posts before. Where did you find those?
Steve at Small Bear Electronics (who created the Tweak-O tutorial) calls them "flea clips" and sells them on his site
here.
