Shin-ei/Univox Uni-Vibe [Replica Files]
- vintagecharlie
Hi folks,
i started a Univibe build. Here are some pics of the board so far:
Some open questions creeped up during the build: - can N4007 diodes be used as a good substitute for SM150, if not, what readily available diodes come closest to the specs/performance of SM150?
Also, could you please help identify the values marked with the beautiful high fidelity yellow circles? They are from Fastockers early univibe, but i could not find any higher res. picture - Jim, if you read this, please let me know. Otherwise, maybe someone else has a higher quality image backed up somewhere?
I have 100k instead of the 200k that is on Fastockers early vibe. What would be the difference be?
I also would like to incorporate the offset bias mod into this build - i suppose i will have to make some changes to the bias circuit for that. Does anyone have a good layout or guide for this - on how to incorporate the offset bias mod to a stock univibe circuit?
Thank you very much in advance!
Regards,
VintageCharlie
I have 100k instead of the 200k that is on Fastockers early vibe. What would be the difference be?I also would like to incorporate the offset bias mod into this build - i suppose i will have to make some changes to the bias circuit for that. Does anyone have a good layout or guide for this - on how to incorporate the offset bias mod to a stock univibe circuit?
Regards,
VintageCharlie
Nice build going on there!
Diodes -- 4001 thru 4007 will work. 4001 is a nearly direct replacement for an SM150 and works fine.
Small cap circled in yellow is a 470pF on my early Uni-Vibe.
Two electrolytics circled are 0.68uF. That's what came on the very early Uni-Vibes and gives a tad faster speeds.
200K was on the early units that didn't have the trimmers. I'd recommend using a 100K in that spot.
I think Adrien hooked up an offset trimmer to his build so maybe check with him . . . ?
JJK
JJK
- vintagecharlie
Thanks for the quick reply and valuable info! Am almost there. Still have to receive the transformer and then figure out how to test everything without electrocuting myself.
- Xplorer
- vintagecharlie
Thanks Xplorer, will first try it stock and then check out this mod.
Board is done for now, waiting for the transfomrer to get here and am awaiting the moment of truth.
Here is the current state:
- vintagecharlie
Hey guys,
i receivewd the transformer and want to put together a test-unit. I have no foot controller, but i have the proper dual pot for speed control and am hence wondering how do the DIN5 pins need to be wired up to the dual pot of the foot controller, in order to work correctly? Thanks a bunch in advance!
Kind regards,
VintageCharlie
Kind regards,
VintageCharlie
- Xplorer
It should be a good exercise to check the schematic and see whatbis what between the circuit and the foot controler, to make the proper connections between what's out of the midi and the controler.
The layout for the foot controler had a mistake and it took le 2 days to spot it, but thanks, the schematic was there.
Awesome thread, would to build one myself. Can someone help? Btw I normally hang out at the Metro Forum as Axeman building Plexi amps and would like to master this build.
Can Someone PLEASE direct me to the layout with the resistor values?beedotman wrote:ok... here's first one - little smaller PCB version (6" x 3.5") some modifications:
# little pcb layout clean up (unified spacing for resistors, capacitors, transistors)
# input resistor on board
# added Bulb Bias trimpot
# pads for electro capacitors has indicated polarity (accordingly to factory schematic)
... and that's all I think...
Component names follows Sinner's schematic.
I checked layout few times, so it should be OK, but I will appreciate verification by some one else.
I'm working on 1590p size PCB with kinda mojo look and component placement, just need to check it once again, will post it soon.
Any comments? Suggestions?
I cant believe this
Hi Arturo,
I can sell you 4 pcs of Secret Magical LDR for the UV. This are discontinued and no possible to find because I bought all the stock available.
If you are interested I can sell you four pieces to 400 u$d.-
Waiting your reply,
David.-
PS: I have audio and videos of a famous guitarrist using and testing my creations. (REALLY HENDRIX SOUNDS)
Hi Arturo,
Waiting your reply,
David.-
- Dirk_Hendrik
for what it's worth,stg44 wrote:I readed the 23 pages, but there is no PCB transfer !
I posted the layout of my resleytone on pag 2 of this thread: viewtopic.php?f=19&t=3533&hilit=psychedelic&start=20
