Shin-ei/Univox Uni-Vibe [Replica Files]
Plexibuilder
Post by Plexibuilder »
Here are the circuit boards and enclosure coming soon
https://www.ebay.com/itm/264947391470
polifemo
Been thanked: 5 times
Post by polifemo »
Plexibuilder wrote: 24 Dec 2020, 06:10 Here are the circuit boards and enclosure coming soon
Great :-)
mwelch55
my favorite amplifier: Modded Marshall
Completed builds: Pedals:
BSIAB2, Tube Screamer Clone, Timmy Clone, Plexi-Drive Clone, Dr Boogie, Rangemaster, GTFO, MicroAmp, Silicon Fuzz Face, Germanium Fuzz Face, Big Muff Pi, Rat
Amps:
Single-Ended Marshall Voiced using 6V6,6L6,EL34,5881,6550, or KT88
Post by mwelch55 »
Does anyone have a good link for the Univibe Replica PCB Transfer files? The wayback machine has several component layout files, but the link to the transfer PCB image is broken. I found the link to the PCB transfer is broken everywhere I have looked on the internet.
Can anyone help? I would like to build a replica and don't want to buy it off of ebay.
Mike
HeyJoe
Post by HeyJoe »
Volk wrote: 07 May 2013, 16:03 My fabrication files
Hello! Have you got any files to Uni-Vibe? :)
marjodp
Post by marjodp »
mwelch55 wrote: 15 Jan 2021, 19:10 Does anyone have a good link for the Univibe Replica PCB Transfer files? The wayback machine has several component layout files, but the link to the transfer PCB image is broken. I found the link to the PCB transfer is broken everywhere I have looked on the internet.
Mike
Hi, Mike
I have saved this file from the turretboard.org.
UV_Transfer_rev1.pdf
(73.04 KiB) Downloaded 481 times
mwelch55
Amps:
Post by mwelch55 »
Thank you for the PDF. I will be trying to build a Univibe based on the Layout I have and the Transfer you posted.
gbkd80
Post by gbkd80 »
Can anyone tell me if Clairex CL604L photocells would work in a replica build? i have a quad of NOS sitting here that I'd happily use in my build if anyone has any insight?
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
marjodp wrote: 17 May 2013, 22:52 Here are some updates:
Hello, how are you?
do you have a pdf file with measurements?
thanks
andreev_ak
Post by andreev_ak »
Hello, guys! Seems like this thread is never gonna be dead =)
I've been building my Uni-Vibe clone for almost 3 years and right now I'm about to get exactly the sound I'm chasing to. I just need to make some minor tweaks. One is about the bottom speed and another one is about the depth. So, I'm building it according to the Neovibe layout (many thanks to R.G. Keen).
1. I managed to get my UV quite fast by swapping C19 and C21 from 1uF to 0.68uF and R42, R43 from 4.2k to 1.8k. But I lost my bottom speed. As far as I understand the schematic, using lower values of C19 and C21 lead to it. So, it's like a compromise, isn't it? Or I missed something? Although some factories clones have both slow and fast (like a Leslie) speed. What else should I try?
2. I used Silonex NSL-7532 with 150-200k - 6.7M light resistance, but in my opinion the depth is not that deep as in some replicas. I'm going to try NSL-5542 and CdS-9203, but I'm not sure about their rise and fall time. What would you recommend? Does anyone have some experience with them.
I'm attaching a link to my recording with the UV.
Eq: Strat -> UV clone -> Hiwatt HD20 -> Celestion G12 -> AT2020 -> Focusrite
https://drive.google.com/drive/folders/ ... u60nizI3RH
Update:
I just soldered up a dual B250k pot and my UV got even faster, like a Leslie. So, it's not still slow enough. :hmmm:
holm
Has thanked: 10 times
Post by holm »
Hi
I wanna be sure I unstand your issue. You wanted to increase the Max speed? And now the oscilation is too fast when speed is at low settings? One thing inerent with the univibe design is that the lamp current amplitude is proportional with the speed. If you exchange the 2 diodes in the LFO, with ones with a higher forward voltage than the often used 1N4001 (fV 0.67 ish), or only use one, will give you a higher amplitude but will also increase the speed.
andreev_ak
holm wrote: 15 May 2021, 14:54 Hi
I mean I managed to make it sound really fast by changing some components (C19, C21, R42, R43, speed pot), but I lost my low speed. A lot of clones on the market have both slow and fast speed. In other words, from Breathe to Any Colour You Like by Pink Floyd (in case someone doesn't know).
So my first question is about this.
The second question is about LDR for the best range of depth. Especially available on SmallBear Electronics.
holm
Post by holm »
Sorry for the late reply
In my clone I have 2K for R42 and R43 and 1µF for C19, C20 and C21, and I'm able to get ok sound similar to "Breathe". When you say you lost your slow speed, do you mean that when the speed potentiometer is set at 0, it's too fast? OR do mean there's no throb at the minimum speed setting?
Regarding the LDRs, I've found there's lot of variation of LDRs with the same specs, and you could buy some expensive LDRs, but to get a good range of depth isn't necessary dependent on the LDRs, to some extent yes, but there's a lot of other parameters. I got 50 pcs of 5547's of ebay cheap, and they work fine.
\Erik
Ali7887
Post by Ali7887 »
Does anyone has shin-ei univibe "Veroboard layout" with parts? Thanks
andregarcia57
DaveAir79 wrote: 24 Mar 2013, 00:53 Hi again...
I modified my replica Shin-ei/Univox Uni-Vibe with 8PDT Switch on the back of the Chassis, so Position 1= Shin-Ei 915 and position 2 = J Sproul (FX Watson) version.
I have to inform taht the pos n°2 is the best for far! More rich harmonics, more speed... more Jimi Hx sounds...
Keep on rockin'
Regards,
DAVE (from Argentina)
hello, how is everything?
looking for information in the search I ended up following your comment. I'm interested in building this sproul version, do you still have the pedal? did you make the video?
thankful
DaveAir79
my favorite amplifier: Plexi Super Lead; AC30; Tweed Twin
Completed builds: UniVibe
Zonk Machine
ToneBender MKI
ToneBender MKII
ToneBender MK1.75 Diablo
Tycobrahe Octavia
FuzzFace (all versions)
Has thanked: 17 times
Been thanked: 16 times
Post by DaveAir79 »
Hi andregarcia57, Yes I'm still building UV replicas.
What are you looking for? Does not exist such thing like Watson or Sproul version... You have the earlier version or the later. It is probably that these names came from which traced the PCB/layout.
Any doubt send me DM.
dave.egea
DAVE
andregarcia57
hello guys, a question about the transformer, I read practically every topic, I didn't find amperage data from the original transformer? how many mA are needed in the pedal? thanks
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
Last one I built drew 60 mA from an 18V DC supply, regulated down to 15V in the pedal.
andregarcia57
hey guys
I have a finished Shinvibe working but I still haven't found a photocell kit that sounds like I'd like.
Is there anything new about photocells?
I've been following work from www.sabbadius.com and his units all seem to sound great, he's using 7mm photocells but there's no specification...
Does anyone have any tips on a photocell that has more intensity?
thanks
https://www.sabbadius.com/?page_id=109&lang=en
"The New 2022 7mm CdS Photocells CUSTOM-MADE for SABBADIUS will increase the throb INTENSITY in all aspects and you are going to feel that swirling sound that JIMI HENDRIX EXPERIENCED with the original Uni-Vibe he used."
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi Andre,
Personally I think that none of the boutique builders around the world can purchase enough volume of components to obtain "custom-made"parts...
Perhaps this builder have depart from the classic 5mm LDR´s and accidentally discover that ones of 7mm in diameter suits better in their designs.
For example, there is a link to 7mm photocells:
https://fuse-china.en.made-in-china.com ... -160-.html
BTW, Mr Sabbadius sold a replica of a wah inductor (also claiming that is an exact reproduction of the legendary HALO) but is merely constructed using standard cores from EPCOS, formerly Siemens.
The Rotagilla
Post by The Rotagilla »
Hey Andre,
Don't get too hung up on the photocells. One big pedal manufacturer claims that his are 100% dead on replicas of the originals when in fact, they look nothing like them. Grab a set from Small Bear (if they still have them) and focus more on gain and offset (hopefully you built yours with trimmers instead of resistors).
Also remember that no two original Unvibes sounded the same. Shin Ei wasn't selecting and matching parts, they were just building them. I've owned six different Unvibes over the years, and they've all sounded slightly different. Some were stronger sounding than others, some had more phasing, etc. Plus... what sounds like a "good" Univibe to me may not sound like a "good" Unvibe to you.
Again, the gain and offset trimmers are going to have the biggest impact on how your vibe build sounds.
The Rotagilla.
