Im a looking for some help
I am building a few SDD-3000 pre-amps from the the design found on http://www.sabrotone.com.
I have the PCB designed apart from the power supply which uses a 9volt power supply.
The oringinal SDD-3000 used a 15v power supply,so I am wounding is there a low cost 9v to 15v converter or circuit that I could use?
I found the following page https://obsoletetechnology.wordpress.co ... ct-pedals/ but i cant find the LT3467's and as im new to this Im not sure if its what I need.
The finished SDD PCB has to fit in a hammond 125 enclosure as I bought 60 enclosure from China for all my projects
If anyone could help it would be greatly appreciated.
Also If anyone knows the SDD-3000 well could you let me know.
