BK Butler - (rackmount) Tubedriver  [traced]
tip142
Been thanked: 15 times
Post by tip142 »
Hi,does anybody have schematic ,i' ve only see guts of an open rack...and see 2 valves inside.Don't know the model.
I'm very curius is simple starved ?Like the other pedal.
Or conventional H.T ?
:hmmm:
Has thanked: 218 times
Been thanked: 857 times
The Chandler Rack version is my site. It has been there for a few years.
http://www.dirk-hendrik.com/temp/Chandl ... r_Rack.pdf
Hape that helps.
tip142
Post by tip142 »
Hi,thank you for reply great pleasure to meet you;the schematic you have does not match what i see...
Look here -
The are 2 (probably) 12Ax7.....
This is my afternoon research:
Is Real Tube II------ Rt -922 design by BK Butler
:hug:
tip142
Post by tip142 »
Here one gut of the inside-
That's a different beast indeed. In the same sloppy workmanship style always seen from Tube Works.
I would need to have it on my bench to trace it. Pretty hard to do from photo's. Shame. Sounds a lot better (in that YT clip) than the single tube tubedrivers.
tip142
Post by tip142 »
I'm with you,it seems that this version is a bit different from the standard creatures of Mr.Bk Butler.
What say?
:scratch:
mozwell
my favorite amplifier: home made SVT2
Completed builds: baja tube driver, several TS variants, Sansamp GT2, Ross Comp
Has thanked: 22 times
Been thanked: 66 times
Post by mozwell »
one of these may be what you want
edit - these are the single tube ones, so not what you are after
Tubeworks Blue Tube schematic .pdf
(407.32 KiB) Downloaded 126 times
tip142
Post by tip142 »
Well,thank you for sharing this schematics;is good having it under our Forum.
Is seems the ,that model is a little obscure for the schem.........
:thumbsup
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi tip142,
Perhaps the schematic of the rack unit that you're asking for has more to do with this diagram: https://www.diystompboxes.com/pedals/sc ... ee_v12.gif
Is an all tube pedal that runs on slightly higher supply voltage, and employ a couple of tubes instead the usual dual operational and a single 12AX7.
Enjoy,
tip142
Post by tip142 »
Ah!Thank you very much;doesn't ever see before;looking wonderful.
Where did you find?
Anyway a little gem....
:applause:
:thumbsup
ppluis0
Post by ppluis0 »
tip142 wrote:Where did you find?
This images were picked in the web. Personally I never seen one of these units.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
How hard would it be to clone one of those Mini Boogees?....... :hmmm:
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
Hey , that two tube , butler is not just a two channel version , two real tubes put together ?
tip142
Post by tip142 »
Well, there is no H.T. present,in the typical range of 280-300 V DC;this is the first reason for considering this effect quite safe;here we are dealing with a secondary voltage in the range that is under 24 v......
In second instance, i don't see anything critical particulary difficulties for build these effects,who differ from standard building.
:mrgreen:
ppluis0
Post by ppluis0 »
The only change I would make would be to increase the value of the first capacitor filter as it has to cover the consumption of the heaters. Maybe 2200 uF would be appropriate.
There is nothing uncommon in the components values or types and also low voltage capacitors can be employed.
Then the only critical parts are the two sockets for vacuum tubes, which usually we get on ebay.
tip142
Post by tip142 »
For this great community:
:horsey:
RT 922 preamp.pdf
(178.94 KiB) Downloaded 346 times
RT 922-924 Switching-FX loop.pdf
(154.11 KiB) Downloaded 222 times
RT-922 & 924 FOOTSWITCH.pdf
(14.01 KiB) Downloaded 211 times
imaradiostar
Been thanked: 8 times
Post by imaradiostar »
I have this unit and love it. Had this and an early 4 knob TD with the single sided board, kept the rack unit and sold the 4 knob version. Mine is the black one.
Jamie
RT 902.pdf
(914.45 KiB) Downloaded 317 times
--moved from requests section---
Thank you gentlemen! Highly appriciated!
