Excalibur - AD-350 Analog Delay [schematic]
- Bernardduur
So, I got this unit in for a pedalboard cleanup and rewire and just wanted to see what's under the hood.......
Bright pink pedal, enclosure just too big for the underside (little gaps on the side).......
From the website:
With 350 milliseconds of variable Delay Time BBD IC the AD-350 can produce a wide variety of time-delay effects, from Rock-A-Billy slap back echo to erratic, runaway delays.
I was guessing some analog delay; but it's not, it is again another PT2399 delay; sigh..........
Will post pics later!
From the website:
- Dirk_Hendrik
Thanks! please do post the pics!
But the good thing (in between the lies) is that it can be modified for a far longer delaytime!
- Dirk_Hendrik
- agoldoor
I love this from the description of their distortion pedal:
"While most other distortion pedals adopt an ordinary transistors and capacitor for their tone circuit, the Holy GRAIL uses a 4558 IC as a simulated inductor in place of the standard coil. "
...A simulated inductor in place of the standard coil... how does that sentence go together? What is that supposed to mean?
- Dirk_Hendrik
the Holy GRAIL uses a 4558 IC as a simulated inductor in place of the standard coil. This ingenious component substitution helps make the HOLY GRAIL's tone circuit smaller and quieter than other pedals.agoldoor wrote:...A simulated inductor in place of the standard coil... how does that sentence go together? What is that supposed to mean?
That circuit is called a gyrator. They're used in countless pedals.
- Bernardduur
- Bernardduur
Hmmmm, I've played it today and I must say I am not impressed........
Boring sounds........
Next, there is a quite annoying gatey noise underneath the bass notes..... higher notes have no issues but lower notes (say from the A on the 6th string) give it with all instruments / cables
Crap!
Crap!
- Bernardduur
Ah yes, they are quite the same
And that Belcat is much cheaper.......
- Bernardduur
One again found it's way on my bench
