MAXON Compressors/Compandors - anyone?
- fuzzbuzzfuzz
Has any one had experience with "vintage" Maxon compressors, and in turn can enlighten as to the differences between them?
There seems to be the (original?) Maxon "Compandor" (small case, rectangular white decals on the sides, no 9v DC) i.e ala the new reissue OD-808, a later version minus the white markings but with a DC input jack on the side, and also the large 08' series type box, CP-101 Compressor. All are 2 knob (no "Attack" function). And of course now is a small box black CP-101 currently in production.
For the record I`ve tried the latter Compandor (today), very light pedal, little squishy but warm, good amount of boost) and a CP-101 - very warm, lovely in fact. But are they all the same inside? (the CP weighs ALOT more!). Are there any duds in the line, are the original series better?
(NB. Not really looking at the intricacies of the circuit, more their sounds, pro`s and cons etc - unless one has a bearing on the other of course )
Super curious!
Thanks all
Super curious!
Thanks all
- fuzzbuzzfuzz
Ibanez CP-835 II I believe is the same as the Maxon CP-101, anyone tried that out?
Looks like this..
http://www.effectsdatabase.com/model/ibanez/808/cp835
Looks like this..
- Dirk_Hendrik
- mictester
The Ibanez has a Maxon PCB inside it!fuzzbuzzfuzz wrote:Ibanez CP-835 II I believe is the same as the Maxon CP-101, anyone tried that out?
Looks like this..
- ilcaccillo
No it's not the same pedal, the Maxon CP101 is an Opto based compressor.fuzzbuzzfuzz wrote:Ibanez CP-835 II I believe is the same as the Maxon CP-101, anyone tried that out?
Looks like this..
the original Maxon CP101 (Red unit) has 1x IC 741, 3x 2SC828 transistors and one LDR/Optosiolator, 2 pots (Sustain and Level)
The new CP101 version (Black unit) it's the same circuit but with input buffer and buffer circuity, and uses 4558 instead of the 741
- Professor SourTone
Mystery solved - appears to be the same board as in the Ibanez CP830
- ilcaccillo
Thats an original Maxon CP101 (Red unit)Professor SourTone wrote: ↑24 Dec 2020, 19:32 I know very little about it. It’s definitely not like a CP101, more like a Dynacomp. It squashes and sustains, but more controllably, also thickens the tone.
I don’t think so, as it does not appear to be an optical circuit, but an Ibanez CP830 in Maxon clothing.
