help identify 3 pots
registracii
Post by registracii »
Hi guys,
Iam trying to make really old phaser usable again, the pots are really bad and need replacement, but I am not sure what to buy.
They have on them D47kMA 0.25W for the depth and regeneration and DM22A 0.25W for the speed.
What pots should I use as replacement?
Duckman
Has thanked: 320 times
Post by Duckman »
D47kMA = 47k Log. 50k will work, too.
DM22A = no k after the 22 but try 20k or 25k log
Can´t you measure with your DMM? Take them out and check value between lug 1 and lug 3. That will be more accurate, for sure.
