nevertheless,
The Ibanez PQL Parametric EQ's schematic now ready for download:
http://www.dirk-hendrik.com/ibanez_pql.pdf
C2 should be 10uFestragon wrote:Cool! Interesting circuit. Reminds me that Boss PQ-4 surfaced a few weeks ago also.
Another oddity in the schem is that the first stage (U1.B) has a high frequency pre-emphasis that adds more than 20 dB between 3 kHz and 30 kHz. If you follow the bypass route via C8, Q2, C9, R18, U1.A, there is no de-emphasis counterpart!
Looks like an attempt to make bass eq peaking instead of shelving, as you said, a quick sim should show wtfigo there. Mid EQ pretty run off the mill standard with its inherent shortcomings. To be fair, it's not supposed to be studio EQ.The Bass control section looks odd, but the network is rather complicated to evaluate without a simulation. Maybe it does work, but in a way seems to be entangled with the High network.
And is 10nSupafuzz wrote: C2 should be 10uF
R19 has been changed on the schematic to 470R so C10, R18 & R19 provide de-emphasis for the >1kHz emphasis in the input opamp but leaves a nice peak at ca 40kHz . Ok, so it's meant to act like a brute force hf noise suppression (it works better with dynamic processors than EQa). Preemphasis + EQ treble boost with these low grade opamps....drive the treble EQ into clipping and with the 40kHz peak you'll be adding britghtening intermodulation products - you just got yourself "I wanna be an aural exciter but I'll be damn if I know wtf an exciter is except for the blue pills beginning with a V".analogguru wrote:R19/C10 is suspicious too since it will not have any influence - except for tone-"experts" - as shown...
Thanks for the info... the last i downloaded was with 510k for R19.R19 has been changed on the schematic to 470R
