This is the amp I referenced here. I semi-traced, semi-copied the schematic that came with it (it's tiny and hard to see clearly) and this is what I have.
For those out there that know tube amps, can this be turned into the Bad Cat mini cat or any other small tube practice amp? I would prefer to use either 1 or 2 EL84s.
